Basic ECU/wiring/sodering questions
Old Jun 1, 2004 | 09:56 AM
HT Chaplain's Avatar
Loved
Default Basic ECU/wiring/sodering questions
How do I hook up my egr valve lift sensor for my egr valve. Its on a hf motor that i swapped in a 90 std with the std harness? It has 3 wires coming out of the plug?
Modified by LEGUTKI at 7:10 PM 6/7/2004
Old Jun 1, 2004 | 11:29 AM
Joseph Davis's Avatar
Default Re: Basic ECU/wiring/sodering questions (LEGUTKI)
No clue what you're asking about in the first sentence, try again?
As far as the best way to solder... you should join the wire with a mechanical connection, and let the solder merely be the electrical connection. Either crimping or twisting the wires together before flowing with solder is ideal.
Old Jun 1, 2004 | 12:14 PM
pgpunkguy's Avatar
Default Re: Basic ECU/wiring/sodering questions (J. Davis)
i think he might be talking about splicing into a ecu wire... maybe...
if that's the case, soldering is the way to go. though time consuming, it's a dependable connection that you won't have to worry about coming loose down the road.
* i would just strip the wire you want to splice into.
* twirl the stripped end of a wire you want to attach around the exposed ecu wire you just stripped.
* then solder the jonx in there
* after you can elec. tape around it or heat shrink (to prevent the soldered wires from touching another wire or grounded surface.
hope that helps... just my $0.02 though...
if you're lazy and don't care about driving yourself crazy later on trying to figure out which wire came loose when troubleshooting something that doesn't work anymore... in that case, just twist and cap
Old Jun 1, 2004 | 12:38 PM
Loved
Default Re: Basic ECU/wiring/sodering questions (pgpunkguy)
Ok im let me explain better im hooking up a egr valve for a HF crx. the egr valve has a plug that connects to it with 3 wires. The ecu pinout chart says it is A10. How do i hook up the 3 wire plug into 1 pin?
Old Jun 1, 2004 | 12:54 PM
5v referrence power pin ???, sensor ground pin ???, sensor return pin A10.
I don't have my OBD0 literature on me right now, but the ref voltage supply and the sensor ground would be the same as the TPS circuit.
Old Jun 2, 2004 | 07:10 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LEGUTKI &raquo;</TD></TR><TR><TD CLASS="quote">Ok im let me explain better im hooking up a egr valve for a HF crx. the egr valve has a plug that connects to it with 3 wires. The ecu pinout chart says it is A10. How do i hook up the 3 wire plug into 1 pin? </TD></TR></TABLE>The ECU pinout only lists the wires that go to the ECU. It's only part of the story. So you need the circuit drawing for the whole sensor circuit, not just the one wire that goes to the ECU. Most likely one's power (from main relay?) & one's ground.
Old Jun 2, 2004 | 10:49 AM
Default Re: Basic ECU/wiring/sodering questions (JimBlake)
I doubt an engine sensor, EGR lift sensor in this case, gets battery voltage as it's referrence voltage. Seeing as how it is not #1 industry standard 5 volt referrence and #2 not a steady, calibrated voltage but fluctuates from 12-14 volts depending on engine speed, I'd bet me right nut it's NOT getting battery voltage.
Old Jun 2, 2004 | 11:43 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">...it's NOT getting battery voltage.</TD></TR></TABLE>I believe you're right. But my point was that an ECU pinout list is not even half the story. LEGUTKI needs the real wiring drawing.
Old Jun 2, 2004 | 12:03 PM
Your right
Old Jun 7, 2004 | 04:05 PM
Loved
ok i got my wiring drawing it looks like its 5v. now what? gound 1 plug, wire 1 into ecu and then how to i get 5v of power?
BTW this is cool im learning
Old Jun 8, 2004 | 03:41 AM
JimBlake's Avatar
How does it get that power originally? Isn't there another ECU pin that supplies the 5v? The ECU that you're using probably supplies regulated +5v to a couple other sensors too, like maybe TPS & MAP? I have to guess since I don't have wiring drawings for either your donor or recipient cars...
hondamyheart
Aug 24, 2018 02:12 PM
Monkey Fing a Coconut
May 28, 2005 06:58 PM
hybrid1990crx
Nov 21, 2004 09:14 AM
Sketch_hs
Aug 19, 2004 08:44 AM
AdamITR
May 14, 2003 05:44 PM
