Feedback on Sparco Harness bar, does anyone have this in their R?
I'm interested in purchase this product, but first I would like some feedback form people who already own this. For instance, is the quality of the material good and how does it get mounted.
http://www.sparcousa.com/harness_bars.asp
I "don't" want to put a roll cage in my car because of the following reasons:
1. Don't want to drill holes.
2. Cargo space and passagers.
Thanks,
Cal
Thanks,
Cal
Harnesses without at least a rollbar are dangerous.
That said, even a rollbar can be dangerous in a daily driver.
My buddy runs a harnessbar in his SM prepared Civic but he trailers it and pretty much only uses it for competition. His bar isn't a Sparco from what I remember but is of good quality and worth it to him for the money he spent.
As well, from the link you provided it looks like you'll still need to drill holes for the vertical bars. I'm sure the application may differ but, I'd contact Sparco to discuss this further.
If holes and drilling are of major concern, personally I think the priorities are a bit askew. Safety should always be more important imo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si »</TD></TR><TR><TD CLASS="quote">$400 seems a little pricey for that
When you consider I got my rollbar for $329. I tend to agree, but it totally depends on your intended application. As per my buddy rodney, in said SM prepped civic, he needed a harness bar obviously and previously had the same Autopower bar as mine but went with the harness bar and saved a crapload of weight which to him for competition is Extremely important.
And I reiterate his car is towed.
</TD></TR></TABLE>When you consider I got my rollbar for $329. I tend to agree, but it totally depends on your intended application. As per my buddy rodney, in said SM prepped civic, he needed a harness bar obviously and previously had the same Autopower bar as mine but went with the harness bar and saved a crapload of weight which to him for competition is Extremely important.
If there is interest we can make harness bars for like $250, we've already done it for WRXs...same if not better quality than the sparco...harness bars are great if you auto-x and just want to use them durring events...I would NOT wear harnesses on the street unless you have a roll bar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep3 No.2 »</TD></TR><TR><TD CLASS="quote">ioport makes harness bars as well.
but whats wrong with wearing a harness for daily driving ?
if you have a harness bar shouldnt you be ok ?</TD></TR></TABLE>
I was wondering this myself y is it bad to roll with harness on the street i can understand not having them if u have nothing to mount them to but from what the description of that harness bar that is xactly what it is intended for to "safely" mount a set of harnesses. I have been looking to get harnesses ever since i got my jdm recaros and i saw the add for the sparco harness bar and thought here is a semi cheap alternative to a roll cage
The idea is that you shouldn't use harnesses w/o rollover protection. A lot of people use these harness bars in autox cars because you get the advantages of harnesses but have a very small risk of rollover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr »</TD></TR><TR><TD CLASS="quote">well your risk of a rollover is kinda limited on the streets </TD></TR></TABLE>
Ultimately its up to you if you want to assume the risks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep3 No.2 »</TD></TR><TR><TD CLASS="quote">but whats wrong with wearing a harness for daily driving ?
Not legal in CA.
Not legal in CA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin ITR »</TD></TR><TR><TD CLASS="quote"> For instance, is the quality of the material good and how does it get mounted. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg »</TD></TR><TR><TD CLASS="quote">As well, from the link you provided it looks like you'll still need to drill holes for the vertical bars.</TD></TR></TABLE>
That harness "guide" bar attaches to the upper (b-pillar) and lower outboard seat belt mounting locations.
I've got one just like Victors (used from Trey Commander).
Interesting to see that they are actually "Sparco" pieces, got mine through Speedware Motorsports/stainless.
These are Speedware units, that Sparco sells. I like mine, and I don't use harnesses. I use it for a camera mount and to stiffen up the center of the chassis. Hit me up if your interested in one.
-Victor
-Victor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 »</TD></TR><TR><TD CLASS="quote">If you don't have a bar and you're wearing a harness and roll over, you're head will be crushed.</TD></TR></TABLE>
How is that different from wearing a regular seatbelt?
some guy i met had harness in his s14 and said that as long and its 45degrees its fine.
he had them bolted to the back seats somehold i think either thru the seatbelts or somthing different, and i ask him.. hey isnt it unsafe to run it without a rollbar and he said no its only unsafe not to have it at a 45 degree... i never agreed with him.. but can anyone clarified
the degree at which the belt has to be mounted is variable. some places recommend various degrees. I know the belts pose a risk of back injury if it is mounted too low, in collisions.
Yeah and the chances of you getting into an accident and rolling over is the same as you crushing your head, chances are very slim. This being said though its still better to be safe than sorry
mister2racer
May 18, 2004 02:12 PM
Outsane
Oct 31, 2003 10:05 AM
