Which direction coolant flows thru rad????
Old Jun 1, 2004 | 07:07 AM
legendboy's Avatar
Default Which direction coolant flows thru rad????
I need to know which way coolant flows thru the rad. I'm plumbing my turbo water pump to the upper and lower rad hoses and i want it to be "going with the flow" I have no idea.
Old Jun 1, 2004 | 07:09 AM
legendboy's Avatar
Default Re: Which direction coolant flows thru rad???? (legendboy)
Actually since when the thermostat opens coolant flows thru the rad, so it must be in the top rad hose and out the bottom rad hose right?
Old Jun 1, 2004 | 08:04 AM
JimBlake's Avatar
Coolant flows downwards thru the radiator. So the upper hose flows from the engine to the radiator, and the lower hose flows back to the engine.
Old Jun 1, 2004 | 04:22 PM
Wes V's Avatar
Default Re: Which direction coolant flows thru rad???? (JimBlake)
It's real easy to remember if you think of the radiator as a water resevoir or sump. There isn't always water at the top and if the engine had to draw from there, the pump would just try pulling air. The bottom always (unless you have a major problem) has water.
Wes
Old Jun 1, 2004 | 06:35 PM
MajorPayne's Avatar
Default Re: Which direction coolant flows thru rad???? (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">It's real easy to remember if you think of the radiator as a water resevoir or sump. There isn't always water at the top and if the engine had to draw from there, the pump would just try pulling air. The bottom always (unless you have a major problem) has water.
Wes</TD></TR></TABLE>
good way to look at it
moncherris_em1
Honda Civic (2001 - 2005)
Mar 28, 2011 05:37 AM
poorman's type-r
Oct 29, 2006 09:18 PM
fanta!
Aug 14, 2005 02:14 PM
goowakjai
Aug 2, 2005 08:59 PM
originalbadbob
Jun 8, 2004 12:46 PM
