Shock/Strut Bump Gaurds
Old Jun 1, 2004 | 04:25 AM
Steak84SS's Avatar
Default Shock/Strut Bump Gaurds
When you guys replaced your shocks, did you replace the bump gaurds or find replacements with a poly/other material? If replaced...with what?
Old Jun 1, 2004 | 04:32 AM
ragejed's Avatar
Default Re: Shock/Strut Bump Gaurds (Steak84SS)
I replaced every bushing in my car with poly ones when I changed out my springs. You dont have to change them, its optional.
I used ES bushings everwhere.
Old Jun 1, 2004 | 04:43 AM
Steak84SS's Avatar
Default Re: Shock/Strut Bump Gaurds (ragejed)
Those kits dont inclide those big bump gaurds on the shock pistons.......
Old Jun 1, 2004 | 05:01 AM
ragejed's Avatar
Ohh You mean those like big O shapped things that the spring actually touches? I thought you meant the bushings that the piston of the shock touches. If you mean the big O things, then there are no replacements for them in poly. I used my stock ones that were on there. No biggie
Old Jun 1, 2004 | 05:18 AM
Steak84SS's Avatar
thanks, all they are for is if the shock bottoms out. Can't say that is necessary for those to be poly. I think I may do the poly kit that you were talking about. Will the rear sway bar bushings accept a larger aftermarket bar?
EM1KeepUp
Jul 1, 2014 06:36 PM
Mike36
Dec 23, 2009 02:00 PM
DAMCOOLDAV
Aug 16, 2004 12:23 AM
solo-x
Sep 26, 2002 08:51 PM
TurbothisLS
Apr 9, 2002 07:35 AM
