lug nut question?
Old Jun 1, 2004 | 02:18 AM
ZensokuEK's Avatar
Default lug nut question?
what kind of lug nut should i use if i'm running arp extended wheel studs on my oem itr wheels? stock or aftermarket? would those muteki lug nuts work?
Old Jun 1, 2004 | 03:23 AM
.RJ's Avatar
.RJ
Default Re: lug nut question? (ZensokuEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZensokuEK &raquo;</TD></TR><TR><TD CLASS="quote">what kind of lug nut should on my oem itr wheels?</TD></TR></TABLE>
Stock, or stock style (same seat time) lugs.
Some honda lugs are open-ended, 90-93 accord, some Del Sol wheels, forget which others.
Old Jun 1, 2004 | 06:04 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: lug nut question? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Stock, or stock style (same seat time) lugs.</TD></TR></TABLE>
More specifically, for OEM Honda/Acura wheels, you will need lug nuts that have a spherical (ball) shaped seating area, to match the seating area on the wheels.
Most aftermarket wheels have a tapered (conical) seating area, and need lug nuts that have the same shape seating area.
Old Jun 1, 2004 | 08:41 AM
itr1244's Avatar
Default Re: lug nut question? (nsxtasy)
Old Jun 1, 2004 | 12:15 PM
ZensokuEK's Avatar
Default Re: lug nut question? (itr1244)
good thing...i almost got those muteki lug nuts, i guess i'm not getting them til i get some new rims...how much do those oem lug nuts run? thanks a lot guys
Old Jun 1, 2004 | 12:24 PM
JiggyKooAndy's Avatar
stock wheels; stick to stock lug nuts
Old Jun 1, 2004 | 12:55 PM
MissMyHonda's Avatar
Default Re: lug nut question? (JiggyKooAndy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JiggyKooAndy &raquo;</TD></TR><TR><TD CLASS="quote">stock wheels; stick to stock lug nuts</TD></TR></TABLE>
He's getting extended wheel studs
Old Jun 1, 2004 | 01:28 PM
nightrider's Avatar
Default Re: lug nut question? (JoesTypeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoesTypeS &raquo;</TD></TR><TR><TD CLASS="quote">
He's getting extended wheel studs</TD></TR></TABLE>
wouldn't that just be threading?
Old Jun 1, 2004 | 01:34 PM
markpaco's Avatar
The lug nut you need is 90381-SV1-901. They list for 0.74 at www.hondaautomotiveparts.com. That should cost you about $15+shipping.
Modified by markpaco at 11:46 PM 6/1/2004
Old Jun 1, 2004 | 01:37 PM
LsV's Avatar
LsV
Default Re: lug nut question? (markpaco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpaco &raquo;</TD></TR><TR><TD CLASS="quote">The lug nut you need is 90381-SV1-901. They list for 0.74 at www.hondaautomotiveparts.com. That should cost you about $15+shipping.</TD></TR></TABLE>
Old Jun 1, 2004 | 01:42 PM
1GreyTeg's Avatar
Default Re: lug nut question? (nightrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">
wouldn't that just be threading?</TD></TR></TABLE>
Extended studs won't allow the OEM closed nuts to seat correctly. He's looking for an OEM style open ended ball/radius nut as indictated by Ken's nifty illustration above.
.RJ's Avatar
.RJ
Default Re: lug nut question? (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Extended studs won't allow the OEM closed nuts to seat correctly. He's looking for an OEM style open ended ball/radius nut as indictated by Ken's nifty illustration above.</TD></TR></TABLE>
90-93 accord
Old Jun 2, 2004 | 02:07 AM
ZensokuEK's Avatar
do they also make wheel locks for open ended ball seated lug nuts? where do i get them
Old Jun 2, 2004 | 09:20 AM
ZensokuEK's Avatar
UP
Old Jun 2, 2004 | 10:30 AM
erottik-R's Avatar
I may never have use for this info..but I gotta say, it feels good to learn somthing..
Old Jun 2, 2004 | 10:58 AM
esponet's Avatar
all honda that came with a aluminum rims that has a center cap to cover the lugs are open ended. if the lugs are exposed, they are closed end.
but if you have a closed end honda nuts, you could pop the cover off. then it would be a open ended lug nut.
as long as your arp studs has the same thread pitch and size, you should be able to use oem lug nuts on oem wheels. after market wheels, go with what they recomend for their wheel.
Old Jun 2, 2004 | 05:54 PM
95gsr's Avatar
i just put extented studs on my gsr and I cut the end peice of the lug for now untill i get the wheels i want. idea
ITRBOY1433
Apr 29, 2009 07:04 AM
showcivic2001
Oct 17, 2008 04:14 PM
Manolo
Suspension & Brakes
Nov 27, 2007 08:30 AM
accorkie
Jul 31, 2007 09:23 AM
99_dc2
Feb 21, 2006 01:05 PM
