Is this a good header for me
Old May 31, 2004 | 09:18 PM
crosswrench's Avatar
Default Is this a good header for me
94 RS with 92000 on it, mostly stock minus tires, wheels, suspension, ram intake, and short shifter. I'm looking at a DC Sports JDM 4-1 header. Right now exaust is all stock, but I'm planning on getting a KTELLER 2 1/2'' stainless system with carsound cat, and magnaflow muffler. So what does everyone think?
Old May 31, 2004 | 09:51 PM
LsV's Avatar
LsV
Default Re: Is this a good header for me (crosswrench)
You have a good start, what are your plans performance wise and where do you want your powerband located? I am assuming you want more of a high power range b/c of the 4-1 header.
Old May 31, 2004 | 09:59 PM
xero-cool's Avatar
Default Re: Is this a good header for me (LsV)
It all depends on what else you are putting on your car in the future....
cams? headwork? intake manifold? etc etc
The engine is a system, and you need the right parts to get it to work right....so if you are staying with the items you already have (including exhaust)....the 4-1 would work ok....you might lose a little power down low but at the higher rpms you will gain some....
generally 4-1 headers are better suited to the high revving VTEC engines because they spend more time in the higher rpms....a 4-2-1 header might suit your application better (mid to high end power) since the non-vtec B18b1 engine drops to about 4k at the 1-2 shift, and to about 5k at the 2-3 shift
good luck
Old May 31, 2004 | 10:28 PM
r0c5t4r's Avatar
I say spend more money on an exhaust rather than a magnaflow. No need to be stingy on an exhaust, your going to have to listen to it everyday so I suggest you get a nicer sounding muffler.
Old May 31, 2004 | 11:31 PM
TeGGY_LS's Avatar
i got a greddy 4-2-1 not on my car yet though.........hopefully it works out great.....kinda got the same setup as u plus a 65 shot
Old Jun 1, 2004 | 11:04 AM
Default Re: Is this a good header for me (xero-cool)
I am looking for more low to mid power, and thought the 4-1 was better. So I guess I was wrong. Someone asked me for plans on my motor? This is my daily driver, and Im going back to school in the fall. So I have to keep on budget. I was planning on building the short block with some higher compression pistons, and having some headwork done with mild cams. Also some tuning with the fuel system. I'm not going all out with the car, I just want to a little faster, and reliable. I only have about 3000 to invest in the engine. And with 92000 on it I dont think it would be reliable with forced induction.
Old Jun 1, 2004 | 11:57 AM
StolenTeg's Avatar
Check out my Kamikaze header that im selling on ebay ( http://cgi.ebay.com/ebaymotors...29739 ) Better then DC header. 4-1 design and 2 piece, Nice header that i brought but didnt get to installed since i got almost all my turbo stuff ready to go in!!! my lose your gain!
#edit* My Header is a 2.5 Inch collector so should be great with your 2.5 inch exhaust set-up.
Old Jun 1, 2004 | 08:22 PM
Default Re: Is this a good header for me (StolenTeg)
T hanks but I already bought the DC. Thanks for the offer
julianbc2
May 7, 2009 07:49 AM
VTECth1s
16
Aug 29, 2006 06:16 AM
Iamcuddles
Jan 12, 2006 12:32 PM
blu3g
May 25, 2005 02:26 PM
93superchargeredcivicex
Nov 24, 2001 08:56 PM
