Pre-swap
Old May 31, 2004 | 06:58 PM
Palingenesis's Avatar
Default Pre-swap
At the end of the summer I'm having my SI engine taken out and throwing in a JDM H22AG1 in it. I wanna do some performance upgrades before that. My question is what are all my possiblities of performance upgrades, perferably hp boosting, that are avalible for me to where I don't have to worry about changing or modifing when I get the swap....you know what i mean. I don't wanna get any upgrades if i'm just gonna turn around and have to modify them after the swap. any and all suggestions are welcome. thanx
Old May 31, 2004 | 07:27 PM
volklude's Avatar
Default Re: Pre-swap (Palingenesis)
if i were u, which i was before i did my swap, i would just save the money man. when u do your swap it will end up costing u more then u think and you will be stuck. take it from someone who knows, save as much as u can before you start a swap like this. its the little things that will kill you and end up holding you up. my car has been down since december b/c of money issues.
if you know your def doing the swap and your getting a used jdm h22, go out and get a new timing belt, water pump, spark plugs, wires, new axles and all that good stuff.
good luck.
Old Jun 1, 2004 | 07:11 PM
Default Re: Pre-swap (volklude)
good point. yeah you're advice is meaningful especially since you're undergoing(went) what sounds like a simular situation.
so exactly what all has to be modified when i change from a H23 to an h22? all those thing you mentioned would you it would be better to get those before or after tha swap?
Old Jun 1, 2004 | 07:16 PM
satan_srv's Avatar
what the hay is an H22AG1?
Old Jun 1, 2004 | 07:29 PM
Default Re: Pre-swap (satan_srv)
H22AG1...as in h22 for the 1 generation (92-96) of h22a model versus the second generation (97-01)
Old Jun 1, 2004 | 07:37 PM
98TypeSH's Avatar
............. someone got a pic of their block that says h22ag1 ?
F22AU
Apr 2, 2008 03:40 PM
lando griffin
May 1, 2006 12:07 PM
ThatCivicGrL
Jun 21, 2005 08:41 PM
monalisa overdrive
Sep 15, 2004 01:54 PM
. o 69 o .
Dec 27, 2002 01:34 PM
