RC Injector Question....PLEASE HELP.
Alright here is the deal. I need a FAST Answer! I have a 93 GS-R ls/vtec. OBD1 running a Hondata S200 w/P28. I bought some used RC 310's off a guy on here. When he sent them to me they had the clips on them and the baggie he sent them in says "2000 GSR OBD2". I removed the clips because the plug works with my harness...I need to figure out if they are Saturated or Peak and Hold. Correct me if i am wrong but i need Saturated correct?? Is there a way to tell by physically looking at the injector or the part number?? I need to figure this out SOON! TIA guys.
Not all RC injectors are saturated.
Measure the impedance of the two pins and it should be about 16 ohms. High impedance/saturated injectors are 12-16 ohms (12 I think for the stock ND's and 16 for the RC/Lucas disc inj's). PnH injectors measure 3-4 ohms I think it is. Regardless of the absolute numbers, the impedance will be much lower on the PnH inj's compared to the saturated inj's.
However, RC only makes 310cc rated (@ 43.5psi) injectors in high-imp/saturated. The part number on the body should read something like SL2-310 I think. If it does, then it's saturated.
Thanx guys.....the part number is sl2-310 which matches what you said. And RC doesnt make a peak and hold 310cc from what i have seen.
totsie7944
Apr 22, 2008 09:18 AM
Integra_Boi
Feb 12, 2003 03:20 PM
