clicking noise from cam gears normal?
Old May 31, 2004 | 04:30 PM
pbizzlegsr's Avatar
Default clicking noise from cam gears normal?
i had the side of my valve cover cut off to have the cam gears and such shown..when the cars on idle there seems to be a clicking noise from the cam gears area..a valve adjustment was done but its still there..is it normal?..i cant hear it when i close the hood though, but the timing belt seems to be spinning quite hard as can be seen from front left wheel area underneath..
Old May 31, 2004 | 06:21 PM
moacsupreme's Avatar
Default Re: clicking noise from cam gears normal? (pbizzlegsr)
I wouldn't think that it would be normal, but could be. What kind of cam gears did you install? I was going to say that it sounds like your valves ticking, but you said that you did an adjustment. I've also heard somewhere about fuel injectors making a ticking sound sometimes, although it doesn't really seem like that would make much sense in this case.
Old May 31, 2004 | 06:37 PM
ekHseries's Avatar
valves usually click, you may also be hearing your injectors, they click aswell, but a little clicking from the valves is normal
Old May 31, 2004 | 07:20 PM
Keno20's Avatar
Could be your tappets?
2kdrift
Mar 28, 2016 10:50 PM
EKJOE
May 16, 2009 09:14 AM
Soccerking3000
11
May 15, 2004 09:29 AM
The-LS
Apr 17, 2003 01:34 PM
