Taking OEM intake resonator box out. Need help ASAP
Old May 31, 2004 | 01:55 PM
AndyD's Avatar
Default Taking OEM intake resonator box out. Need help ASAP
Hey guys, I am in the final stages of getting my resonator box out. I took the two screws off. It feels loose but if wont come out. What's holding it in??
Any advice??
Old May 31, 2004 | 02:04 PM
spnbb2
Guest
Posts: n/a
theres a 3rd bolt between the resonator box and the front bumper/fender
take the turn signal out and pull th bumper out slightly from the wheel well and you should be able to see it a lil bit
good luck though it is DEF a PITA to get a wrench or socket around that bolt
Old May 31, 2004 | 02:08 PM
hOndafienD 04's Avatar
mines came out easy....i had my bumper out when i did it...but there is a 3rd bolt...
Old May 31, 2004 | 02:09 PM
AndyD's Avatar
Default Re: (Ludinitup)
Cool. Thanks.
I will try that
Old May 31, 2004 | 02:16 PM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludinitup &raquo;</TD></TR><TR><TD CLASS="quote">theres a 3rd bolt between the resonator box and the front bumper/fender
good luck though it is DEF a PITA to get a wrench or socket around that bolt</TD></TR></TABLE>
you beat me to it
Old May 31, 2004 | 02:40 PM
PetroGuyX's Avatar
so you don't have to take your bumper off to get the resonator out?
Old May 31, 2004 | 02:44 PM
nope....just that undercover....but i needed to take out my bumper, so i did it liek that...took me like 5 mins.....taking out the bumper took me about and hour....lol
Old May 31, 2004 | 05:25 PM
AndyD's Avatar
Default Re: (hOndafienD 04)
I took the bumper screw out and pulled it back a little. It was actually pretty easy to get to once I pulled the bumper panel away a little. I could then see where the bolt was.
Old May 31, 2004 | 06:13 PM
Matgallis's Avatar
Default Re: (AndyD)
that little terd took 30 minutes to remove..
Old May 31, 2004 | 07:05 PM
yOnKiNaToR's Avatar
Default Re: (Matgallis)
yeah...i never thought of pulling the bumper partly out so i just got pissed and ripped the resonator box out then undid that screw. hehe...not the smartest way to do it.
Old Jun 1, 2004 | 12:03 AM
vinuneuro's Avatar
Default Re: (yOnKiNaToR)
wait,so how do you take it out without taking out the bumper? Which under cover are you refereing to?
Old Jun 1, 2004 | 03:45 AM
h4rp0on3r's Avatar
Default Re: Taking OEM intake resonator box out. Need help ASAP (AndyD)
http://www.ntpog.org go to the "mods" section, the removal of the resonator is under "installing an after-market intake"
Old Jun 1, 2004 | 06:30 AM
AndyD's Avatar
Default Re: Taking OEM intake resonator box out. Need help ASAP (h4rp0on3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h4rp0on3r &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ntpog.org go to the "mods" section, the removal of the resonator is under "installing an after-market intake"</TD></TR></TABLE>
That's exactly where I got my install instructions from. However, the 4th Gen is a little different.
0utaSight
Aug 20, 2007 03:32 PM
gosu08
Oct 18, 2006 01:09 PM
sohctodohc
Apr 11, 2006 01:06 AM
DJCRX
May 24, 2002 09:51 AM
IAIA
Jan 11, 2002 02:23 PM
