loose flywheel?!?!?!?!
Old May 31, 2004 | 11:20 AM
GSR Acura-C's Avatar
Default loose flywheel?!?!?!?!
I took my starter off the other day because i thought it was bad then i checked my flywheel turning it, checking teeth, etc... and i noticed it wiggled a little bit in there. If i'm not mistaken the bolts are torqued to 70 lbs. so the flywheel shouldnt move at all in there should it? is this the reason my car just kinda grinds when i try to start and it doesnt start? Thanks a lot guys
Old May 31, 2004 | 11:22 AM
m R g S r's Avatar
Default Re: loose flywheel?!?!?!?! (GSR Acura-C)
I think it's 76lbs, but even if they are torqued to 70lbs it shouldn't move.
Old May 31, 2004 | 11:41 AM
tilt's Avatar
yeah there shouldnt be any play.
you might want to replace the bolts and use loctite. make sure the threads are clean of contaminant like grease/oil.
Old May 31, 2004 | 12:12 PM
Default Re: loose flywheel?!?!?!?! (tilt)
thanks for the help guys, appreciate it...
I didn't know the flywheel was 2 pieces til i ripped off my tranny. The teeth came separated from the disc then when i tried to start it was just spinnin the ring of teeth around the disc therefore not turning over.
Thanks again guys...
end thread
Modified by GSR Acura-C at 1:32 AM 6/1/2004
01LUDEebp
Sep 19, 2016 11:14 AM
wakaranai
17
Sep 14, 2016 07:02 PM
civic_driver
13
Oct 24, 2005 07:51 PM
lilcasino
Aug 4, 2002 08:25 AM
lilcasino
Aug 4, 2002 12:52 AM
