JDM cluster
Old Nov 10, 2001 | 12:38 PM
OmegaLS's Avatar
Default JDM cluster
im having problems w/ my cluster...apparently i did buy a bunk cluster and the guy i bought it from is being less then helpful about giving me back my money .... well heres wats wrong w/ it....the heat gauge is zeroed in at about 1/3 (the temp when ur car is already warm)....the speed is a lil more jacked up....it resets to zero when there is no power at all hooked up to it, but when u hook up the power and leave the car off....it goes up to 20 km/h and when the ignition is on the ON position it jumps up to 60.....i opened it up and tried to tinker w/ the gauges and try to reset them but have no clue how to...anyone have any clue how i can adjust this??
Old Nov 10, 2001 | 01:41 PM
OmegaLS's Avatar
Default Re: JDM cluster (fuzznuts)
the dealer??would they even touch the cluster since it could be considered tampering w/ it or watever???and wouldthey know how to adjust a jdm one??
Old Nov 10, 2001 | 04:24 PM
EPGONZALEZ's Avatar
Default Re: JDM cluster (OmegaLS)
id it a jdm cluster? if so do a search...there is a fix to make jdm clusters work in a us car
Old Nov 10, 2001 | 04:34 PM
OmegaLS's Avatar
Default Re: JDM cluster (EPGONZALEZ)
do u know wat i should search for???i searched b4 i posted for like an hour but couldnt find much
Old Nov 10, 2001 | 04:41 PM
EPGONZALEZ's Avatar
well..to get my jdm cluster to work..i had to take off the gauges..and put them on the board from my itr...make sense?..so just change over the four gauges...
Old Nov 10, 2001 | 04:42 PM
OmegaLS's Avatar
good idea.....also did u have any of the problems i had?
Old Nov 10, 2001 | 04:46 PM
EPGONZALEZ's Avatar
yes...good luck..maybe buy some of those white cotten gloves to do it..if you get fingerprints on the glass..your screwed..hard to get off
Old Nov 10, 2001 | 04:47 PM
OmegaLS's Avatar
i know i already got finger prints on it grrr....wat can i use to get that off
Old Nov 10, 2001 | 07:44 PM
OmegaLS's Avatar
actually i just realized by taking out the gauges and puttin them in my usdm one does the samething as just removing the circuit from my usdm cluster and puttin it on the jdm one...which i had already dun....so i cant figure it out at all
Old Nov 10, 2001 | 10:10 PM
GZR4DR's Avatar
I have a 94 GSR and i put the JDM ITR cluster in my car. Direct plug and play procedure. Not sure if the newer tegs are different though. If they are not, you got a bunk cluster.
dkrex001
20
Dec 19, 2007 04:21 PM
BolivianDc2
Apr 23, 2002 06:00 PM
M0NEYnH0s
Jan 8, 2002 12:25 PM
