what spring or coilover is needed for..
i just want something that is good enough so i can maybe use it for road race or autocross but im not using it forrace(just everyday drive with good suspen.). I DONT WANT TO Pay Much for it. its for a 95 hatchback wtih a b16 motor.
i have some lowering spring that are cut so its even lower.(any good?)
what i want to know is what is the best height to lower to, are the no name or cheap 70 dollars coilover or springs any good, and what best setup for road race.
i have about 6 questions or so, so please help out u pros out there
Cutting your springs will improve looks but your car will handle much worse than stock. Ride quality sucks.
Cheap springs and coilovers are good for show only. Your car will sag under weight and bottom over bumps.
You will want the Ground Control coilovers that are specific to a B series swap. Pair those up with some decent struts, like Tokico Illumina, Koni, etc. Alternatively you could buy the Tokico Illumina coilover set. Tein is popular but I don't have personal experience with them, but I know that you don't want their cheapest set. If you cheap out on the struts or buy generic springs, you can forget about handling.
Optimum ride height on a EG is about 1.75 inches lower than stock. Or about a 44mm drop.
stevieteg
Mar 16, 2005 01:45 PM
