new tps questions... what about the gasket?
Old May 31, 2004 | 12:54 AM
frenchy's Avatar
Default new tps questions... what about the gasket?
ive been having tps probs ever since i swapped tbs - the voltages are ok but i still get some intermittent idle probs and the occasional cel (#7) - im almost positive the sensor is good but the gasket got a little thrashed, prob is you cant just buy the gasket, and if there was one in the first place, im sure its for a reason - if i cant find one can i make one? - out of what? tia
Old Jun 1, 2004 | 08:18 PM
frenchy's Avatar
Default Re: new tps questions... what about the gasket? (frenchy)
does anyone hve suggestions?
Old Jun 1, 2004 | 09:48 PM
typeR#0427's Avatar
There should be a gasket, I would try and replace that first. If there is a leak in the old one that might be the problem. Should be pretty cheap from Honda.
Old Jun 2, 2004 | 08:04 AM
frenchy's Avatar
Default Re: new tps questions... what about the gasket? (hamB18C1)
there is a gasket, and i would replace it but checking online it looks like i have to buy the whole tb to get the gasket, i thought about high temp thermostat gasket stuff but that seems like it would just make a mess, anyone else?
Old Jun 2, 2004 | 02:09 PM
91DAveLS's Avatar
Ok...you can get some gasket paper from your local auto parts store and make your own for about 6 dollars...that's what i did....or you can drop like $30 and get one from a honda cbr 600, i believe, from your local honda motorcycle dealer.
Good luck
Old Jun 2, 2004 | 02:59 PM
StyleTEG's Avatar
Default Re: (TDaddy)
You could just coat both sides of your current (somewhat messed up gasket) with an RTV. It should seal it pretty well.
Old Jun 2, 2004 | 05:39 PM
rev2ninetyper's Avatar
Default Re: (StyleTEG)
cork gasket material, should work fine. rtv might mess with the sensor a little. thats my 2 cents!
Old Jun 2, 2004 | 05:59 PM
StyleTEG's Avatar
Default Re: (no2accord)
The sensor is nothing but a spring loaded arm that twists with the TB shaft. There is nothing to mess with.
Old Jun 3, 2004 | 07:29 AM
Xsi's Avatar
Xsi
I just made one for mine with some gasket paper, the old one was pretty shabby.
Trace it out first, get an adult to help with the scissors
Old Jun 3, 2004 | 06:13 PM
frenchy's Avatar
Default Re: (Xsi)
thanks guys, if i use the plastic safety scissors can i do it myself?
Old Jun 3, 2004 | 09:48 PM
typeR#0427's Avatar
Default Re: (frenchy)
I hope so
Old Jun 4, 2004 | 10:01 AM
hadehatch's Avatar
Default Re: (hamB18C1)
I noticed this gasket on some motors that havent been tampered with.. when I replaced my tps I never replaced the gasket and I havent had any problems.. Same goes for a few friends who have done the same thing..
Old Jun 5, 2004 | 12:36 PM
frenchy's Avatar
Default Re: (hadehatch)
i wondered about the neccessity of a gasket - besides the old "if they put one on it must be there for a reason", i dont see were you need one
Old Jun 5, 2004 | 12:43 PM
StyleTEG's Avatar
I guess its possible that some vaccum could slip by around the TB shaft. It might be a "Just in case" sorta thing.
Old Jun 5, 2004 | 09:17 PM
hadehatch's Avatar
a bit off topic but does anyone know where and how i can get a new TPS? Honda seems to want to sell the whole TB and will not sell a seperate TPS..
Does anyone know a workaround to obtain a new TPS? maybe off the CBR like someone said about the gasket?
Old Jun 6, 2004 | 10:12 AM
frenchy's Avatar
i asked in the bike forum and the only answer i got was that 01+ cbrs had the same tps - im in the process of trying to find an online parts dealer, but not having a lot of luck
Old Jun 6, 2004 | 01:07 PM
Lewis7789's Avatar
Ebay has one...?
http://cgi.aol.ebay.com/ebaymo...%3AIT
Old Jun 6, 2004 | 09:23 PM
hadehatch's Avatar
Default Re: (Lewis7789)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewis7789 &raquo;</TD></TR><TR><TD CLASS="quote">Ebay has one...?
Getting a used one is not hard but they arent that reliable.. I've been using old ones but I would like to know where i can get a new one if thats possible..
Thanks though..
Old Jun 7, 2004 | 02:28 PM
Lewis7789's Avatar
I agree totally with you on that one. I'd buy all NEW sensors. Figured I'd ask... good luck.
journeyquest
Sep 3, 2010 12:39 AM
WalkerGSR1
Nov 7, 2006 01:41 PM
civic_driver
Sep 25, 2005 11:51 PM
jbell
Sep 10, 2005 09:57 PM
yeegsr
Nov 16, 2004 12:05 AM
