question about injectors
Old Nov 10, 2001 | 11:50 AM
mr2's Avatar
mr2
Default question about injectors
what size should I get for my EG hatch? will stock supra 550CC work on my car? oh yeah with a b18c1
Old Nov 10, 2001 | 01:15 PM
civicrr's Avatar
Default Re: question about injectors (white eg)
550 's will be overkill. If you are running na, you will be running way too rich. If I remember correctly, the Civic's & the Integra's all had 235 cc/min injectors, except for the b18c5, which had something like 270's. Besides the ecu (fuel maps) the difference was in the fuel regulator. The regulator had a higher pressure which caused more fuel to be injected per squirt. I am selling some RC 240s if you are interested, check out the other thread with RC in the title. You might be able to get away with 270's without the ecu throwing a code (for too rich at idle).
[Modified by civicrr, 2:17 PM 11/10/2001]
Old Nov 10, 2001 | 04:14 PM
mr2's Avatar
mr2
what do you recommend for a b18c1? 240?
Old Nov 10, 2001 | 08:43 PM
CRX_VTEC's Avatar
Go with RC 270cc....they should be good enough no matter how much you mod your car in the future. (N/A)
Old Nov 10, 2001 | 11:54 PM
FSTASNTZ's Avatar
The ITR also runs a 235CC.
What injector? Depends on the mods...
Jason
Old Nov 11, 2001 | 09:21 AM
rainforest's Avatar
Default Re: question about injectors (FSTASNTZ)
get 97 and above prelude injectors they are 280cc and will work on your car.
Old Nov 11, 2001 | 12:06 PM
Honda318dx's Avatar
Default Re: question about injectors (rainforest)
I got a set of those injectors, will sell them cheap.. and they are 290cc... They would work great for a B18C1..
Old Nov 11, 2001 | 01:12 PM
mr2's Avatar
mr2
Default Re: question about injectors (Honda318dx)
how much?
Old Nov 11, 2001 | 04:30 PM
Honda318dx's Avatar
You got mail..
Old Nov 13, 2001 | 09:23 AM
eternal21's Avatar
get 97 and above prelude injectors they are 280cc and will work on your car. I got a set of those injectors, will sell them cheap.. and they are 290cc... They would work great for a B18C1..
You are correct, they do work great. Just a word of advice, however...if you're using an OBD-1 harness on that B18C1, you will have to get a Dremel and slightly modify the injectors to make it snap into the harness. It's about 15-20 mins worth of work, but seeing as I paid $80 for mine vs $250+ for a set of RC Eng 270 cc injectors...you do the math
Old Nov 13, 2001 | 11:33 AM
Honda318dx's Avatar
Default Re: question about injectors (eternal21)
They are still for sale if anyone is interested
Briyumbero
Nov 13, 2008 05:24 AM
DIRTYsouthBB6
Nov 8, 2007 08:23 PM
russianswty
27
Nov 14, 2006 06:30 PM
cutt
Apr 25, 2006 12:12 AM
