For those with BOTH VAFC and RSM
Old May 30, 2004 | 09:26 PM
JDMflavor_EJ's Avatar
Default For those with BOTH VAFC and RSM
Hey guys.
Just got a free RSM from my brother
I already have a VAFC hooked up.
Anyways can I just simply tap everything from the VAFC harness, such as power/ground/RPM (obviously not speed). Thanks.
Old May 31, 2004 | 01:15 AM
coil222's Avatar
yes i did it that way
RSM is EASY... like 5 wires to solder.
Old May 31, 2004 | 01:16 AM
coil222's Avatar
Here's the write up i wrote for it
http://hondaprelude.to/article....html
Old Jun 1, 2004 | 09:01 AM
matix's Avatar
I just tapped them both into the ecu harness works perfect.
Old Jun 1, 2004 | 10:25 PM
JDM H22A's Avatar
Default Re: (matix)
make sure you dont solder too much to those wires cause it can cause your wires to burn since theres so much running off it. try putting a fuse tap in between
Old Jun 1, 2004 | 11:53 PM
matix's Avatar
thanks for the heads up I will do that
fittyonefittyx73
Dec 27, 2003 12:35 PM
LSTEG96
Nov 6, 2003 09:14 PM
tegon-gsr
Jun 5, 2003 04:40 AM
IgniteTeg
May 1, 2002 03:57 AM
ArchAngel Sabastian
Dec 7, 2001 06:05 PM
