Steering boot, I'm lost
Old May 30, 2004 | 06:48 PM
typeS's Avatar
Default Steering boot, I'm lost
I have a cracked steering boot. Not on the CV axle, but on one of the steering components near the front wheel. What is this? Should there be grease or any fluid in there? How quickly do I need to replace this and how hard is it? Thanks for any help.
1994 2.2 SOHC, 99,000 miles, KYB AGX, Eibach pro-kit
Old May 31, 2004 | 09:00 AM
SKDRCR's Avatar
Default Re: Steering boot, I'm lost (typeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeS &raquo;</TD></TR><TR><TD CLASS="quote">I have a cracked steering boot. Not on the CV axle, but on one of the steering components near the front wheel. What is this? Should there be grease or any fluid in there? How quickly do I need to replace this and how hard is it? Thanks for any help.
1994 2.2 SOHC, 99,000 miles, KYB AGX, Eibach pro-kit</TD></TR></TABLE>
that boot is to keep dust and grime out of the rack.
it doesn't hold any fluid or anything. mine has a crack in it as well.
you could use some tape or something to temporarily fix it.
Old May 31, 2004 | 10:32 AM
del_parker's Avatar
if you replace it, either mark on the threads where the nut came up to before you loosen/remove it to take the boot off or you'll need to get an alignment done to fix the toe angle once you put everything back together.
noobaccord
Oct 25, 2011 11:54 AM
rcalzarette
Aug 8, 2008 06:16 AM
hueyduey
May 19, 2007 12:30 AM
jdser92
Suspension & Brakes
Jan 6, 2006 04:25 AM
badpootie
May 4, 2005 07:23 AM
