Slicks? Yeah I searched, but what better opinions
Old May 30, 2004 | 03:28 PM
HondaAccordSiR's Avatar
Default Slicks? Yeah I searched, but what better opinions
03 Accord, I want to try slicks.
What is a DOT approved tread that I can use that still counts as street? And 15's, but what's the width I can fit. Right now I'm running 17x7.5 Rota Subzeros, probably could squeeze another inch before hitting.
Thanks
Old May 30, 2004 | 04:07 PM
Default Re: Slicks? Yeah I searched, but what better opinions (HondaAccordSiR)
looks like I can squeeze a 25 inch or less tall, 8 inch wide...
slightly smaller is better? a little more power to hit the ground, but there must be a point where you sacrifice the patch touching the ground.
Old May 30, 2004 | 05:48 PM
Jared's Avatar
all depends on how much power you are making
94gsr4dr's Avatar
A 25 is a pretty big slick man, any mods to that car?
Old May 30, 2004 | 06:06 PM
1 2 NV's Avatar
id highly suggest keeping that rolling tank off of slicks.
Old May 30, 2004 | 07:04 PM
Default Re: Slicks? Yeah I searched, but what better opinions (Jared)
guessing around 185 hp @ 2800 lbs without spray. I have horrible wheel hop when trying to launch, learning to slip the clutch. spray in second with a 75 wet shot.
so far the car traps around a 98 mph, my 60' are horrible at 2.4 secs. I've added a bottle heater and hope that see traps over 100mph
never messed with slicks, need some help
yes, the car is slightly stripped...
Old May 30, 2004 | 07:12 PM
cul8tr's Avatar
I got a NEW pair of M/T 23 x 8.5 x 15 that will work perfectly for your Accord.
You can use a 15" rim
$100.00 each plus ship.
Im me if you are interested.
nice22066@aol.com
Old May 30, 2004 | 07:16 PM
Default Re: Slicks? Yeah I searched, but what better opinions (cul8tr)
I'm curious if there is a point where too much is too much and the motor will bog down. Right now I've found that launching anywhere above 2grand is wheel hop. anything less is bog then some hopping.
using potenzas with 17" rota's subzeros, just pulling up and running, no warming up the street radials.
Old May 30, 2004 | 07:17 PM
email sent
boosted.si04
Aug 18, 2010 01:18 PM
GIZZ - EXV
Mar 30, 2010 07:53 PM
200TS EC
Aug 24, 2007 03:14 PM
tkHBseries
Feb 24, 2005 11:10 PM
Burke
Jun 16, 2003 04:54 AM
