My car won't start!! I need help!!
Old Nov 10, 2001 | 09:39 AM
REDBARON's Avatar
Default My car won't start!! I need help!!
Hey I just installed a used Throttle Body in my 90 civic with a 95sohc vtec motor. I put a new gasket and everthing, and it won't turn over. What do I do??
I've replaced my currect one because the throttle angle sensor broke and my check engine light was on. I installed everything back the way it was and it just keeps trying to start but won't come on fully. WTF!!! I really need help guys.
Old Nov 10, 2001 | 09:50 PM
Maxi's Avatar
Default Re: My car won't start!! I need help!! (VTECHatch)
probably related to your distributor if the engine won't fire up. You are hearing the starter cranking away but the engine won't turn over, correct? First thing you'll want to do is check for engine codes. This will tell you what the source of your problem is.
[Modified by Ddddave, 10:51 PM 11/10/2001]
jdmDAsix
Aug 10, 2005 01:01 PM
allmotorej8
Oct 5, 2004 12:45 PM
REDBARON
Nov 13, 2001 06:22 PM
REDBARON
Nov 11, 2001 08:32 PM
