Oil leak from drain plug, any solution?
Old May 30, 2004 | 01:14 PM
infamousasian's Avatar
Default Oil leak from drain plug, any solution?
I got an oil leak from the drain plug on my DA, i replace the plug but it won't tighten up. Is there any solution without gettin a new oil pan. I read other post about using teflon tape, could anybody explain the procedure on doing that.
Old May 30, 2004 | 02:19 PM
G-bonic's Avatar
Hijacked
Default Re: Oil leak from drain plug, any solution? (infamousasian)
its gonna do the same thing when u get teflon tape over it and plus its gonna get burn coz ur engine gets really really hot.. so quit saving money and go change ur oil pan u gonna have to change it anyways coz u lost the thread of it.. u dont want ur car ran out of oil while u runnin, that will cost u a lot more.......
Old May 30, 2004 | 02:20 PM
Axle's Avatar
Default Re:
The previous owner of my car took half a dozen little metal slips he cut from an aluminum sheet and layered them, then tightened the drain plug real tight and so far, it hasn't dripped any.
Old May 30, 2004 | 04:49 PM
00b18b's Avatar
try using a new crush washer?
Old May 30, 2004 | 09:49 PM
darrinbrewer's Avatar
Default Re: Oil leak from drain plug, any solution? (00b18b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00b18b &raquo;</TD></TR><TR><TD CLASS="quote">try using a new crush washer?</TD></TR></TABLE>
WITH a crush washer mine dripped, so i took the washer out, got a new drain plug and pu tit on WITHOUT a washer, and it doesn't leak anymore
i've heard that the auto tranny drain plug fits the oil drain hole, and it's magnetic to catch metal floating around...but i haven't confirmed this..
Old May 30, 2004 | 10:09 PM
4crx4me's Avatar
Default Re: Oil leak from drain plug, any solution? (darrinbrewer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darrinbrewer &raquo;</TD></TR><TR><TD CLASS="quote">
I have never heard this before.
Was the crush washer new?
Almost all oil leaks are from re-usig a used crush washer.
The crush washer isn't supposed to keep it from dripping, that's the job of the drain plug. The washer is used to keep the drain plug from being over-tightened.
Old May 31, 2004 | 06:59 PM
Default Re: Oil leak from drain plug, any solution? (4crx4me)
when i got my car it never had a crush washer, and i continued to use the existing drain plug...for over a year..well a few months ago, i bought a new crush washer, and drain plug...it appeared to leak a little, so i removed the washer, and just use the new drain plug ONLY now...
hydengr
Honda Civic (2001 - 2005)
Jun 11, 2013 03:50 PM
rdean
Mar 26, 2011 01:09 PM
dwn2earth922
May 3, 2007 08:30 PM
ahloung
14
Mar 14, 2006 10:29 AM
mitch3814
Apr 5, 2005 06:37 PM
