wiring problem on a mpfi >>> dx to Si
Old May 30, 2004 | 11:55 AM
importboi22's Avatar
Default wiring problem on a mpfi >>> dx to Si
alright my car keeps giving me a CPS check engine light
wiring is
c1 and c2 are wired up to the distro in the right spot
i moved b1 to b10
is that correct?
Old May 30, 2004 | 04:39 PM
Default Re: wiring problem on a mpfi >>> dx to Si (importboi22)
noone knows huh...
Old May 30, 2004 | 07:48 PM
unno
Old May 30, 2004 | 11:55 PM
ijjz's Avatar
I dont know off hand which wires they go into, the spots (b1, b11, etc) but have you tried switching the c1 and c2 wires you added? Been over a month now since I did mine.
For the correct spots, Hcivic88 and Fourthgenhatch has good guides.
Old May 31, 2004 | 02:00 AM
Default Re: wiring problem on a mpfi >>> dx to Si (ijjz)
c1 and c2 are in the correct spots i've even switched them =\
Old May 31, 2004 | 10:30 AM
Bgladfelter's Avatar
-Pins B10 and B12 are empty meaning there are no wires going into them as a general rule, however some models have a wire at B12. If you have wires there depin them and pull them out.
-Depin C1 and C2 from their plug and plug C1 into B10s spot and C2 into B12s spot. By doing this you just saved yourself the need to solder any cut and solder at least 2 wires.
-Pins B2 and B11 have wires going into them but they are not used for anything (weird, but trust me on this one).
-Take the pin/wire from B2, depin it (this means pop it out of the plug). Now solder and heatshrink on a length of wire long enough to reach into the engine bay all the way to about 1ft after the fire wall. I say this because I like to add a plug right after the firewall later on so you can unplug your whole engine harness if you ever need to. You can do this in comfort outside of the car. Once you are done pin this wire into C1's now empty spot.
-Take the pin/wire from B11, depin it and solder and heatshrink a length of wire onto it just like you did for B2. Once you are done pin this into C2's now empty spot.
per http://fourthgenhatch.com/mpfi.html
used this last week, runs great.
Old May 31, 2004 | 02:31 PM
Default Re: wiring problem on a mpfi >>> dx to Si (Bgladfelter)
will try it!
ryanevansoh
Mar 27, 2009 04:06 PM
thedudefromjerz
Feb 20, 2008 08:17 AM
iheartamy
Dec 23, 2006 08:43 AM
90jdmcrxdude
12
Jul 8, 2006 10:11 AM
sedan squad
10
Mar 19, 2006 11:33 AM
