What's your VTEC engagement set at?
Old May 30, 2004 | 09:53 AM
SpeedingHatch's Avatar
Default What's your VTEC engagement set at?
Mine was 5100
Now its 4700 thanks to VAFC and tuning
So what is yours? And did you find out anything useful by lowering VTEC engagement, whether it be Hondata of VAFC
Old May 30, 2004 | 12:53 PM
Boostindrvr's Avatar
Default Re: What's your VTEC engagement set at? (speedinghatch)
5200-4950
Old May 30, 2004 | 01:43 PM
Kal's Avatar
Kal
Default Re: What's your VTEC engagement set at? (Boostindrvr)
stock, there's no fun in lowering VTEC unless you have a really light flyhwheel and you want to stay in VTEC while you upshift. Otherwise, it's an awesome way to burn gas.
Old May 30, 2004 | 01:58 PM
94Vtecluder's Avatar
Default Re: What's your VTEC engagement set at? (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">stock, there's no fun in lowering VTEC unless you have a really light flyhwheel and you want to stay in VTEC while you upshift. Otherwise, it's an awesome way to burn gas.</TD></TR></TABLE>
Old May 30, 2004 | 02:43 PM
H22A1TLUDE's Avatar
mines hits at 5100
Old May 30, 2004 | 03:47 PM
Eddiebx's Avatar
first off, if your falling out of vtec on the upshifts with a lightened flywheel, u need to learn to shift.
secondly, you can gain 25+ whp in the midrange just by lowering vtec alone, so I hardly call that insignificant.
And to the original poster, i usually set the vtec to about 4700-4800 on a mostly stock motor, that shows the most gains and smoothest power delievery on the dyno.
Old May 30, 2004 | 04:15 PM
sharkcohen's Avatar
Default Re: What's your VTEC engagement set at? (Eddiebx)
4000, but I'm blown
Old May 30, 2004 | 04:38 PM
Memo6453's Avatar
i have a vtec controller and the motor starts to open up @ 5000.
someone told me when you lower it past 5000 it doesnt idle right and ur gas mileage sux
Old May 30, 2004 | 04:47 PM
sharkcohen's Avatar
Default Re: What's your VTEC engagement set at? (Memo6453)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Memo6453 &raquo;</TD></TR><TR><TD CLASS="quote">someone told me when you lower it past 5000 it doesnt idle right </TD></TR></TABLE>
Someone didn't know what they were talking about. Idle has nothing to do with vtec engagement.
Old May 30, 2004 | 05:13 PM
Joon525's Avatar
Default Re: What's your VTEC engagement set at? (sharkcohen)
Used to be 5250 RPM.
Got it tuned and it was set to 4800 RPM.
Got it tuned again with cams and it's at 5200 RPM.
Modified by Joon525 at 7:31 PM 5/31/2004
Old May 30, 2004 | 06:14 PM
sharkcohen's Avatar
Default Re: What's your VTEC engagement set at? (Joon525)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joon525 &raquo;</TD></TR><TR><TD CLASS="quote">Got it tuned again with cams and it's at 5200 RPM.</TD></TR></TABLE>
But that's not surprising since you are now running different cams.
Old May 30, 2004 | 09:02 PM
stRodda's Avatar
ditto. i have crower 2's and vtec is at 5200. if i set it lower, i feel a lag if engaging in 3rd/4th.
Old May 30, 2004 | 10:11 PM
Alstare's Avatar
Default Re: What's your VTEC engagement set at? (stRodda)
on @ 4900rpm
off @ 4500rpm
only activated over 20% tps, 150`F,
Old May 31, 2004 | 09:50 AM
Default Re: What's your VTEC engagement set at? (Alstare)
Anybody actually go below 4500 that isn't F/I ?
Old May 31, 2004 | 01:11 PM
Eddiebx's Avatar
with stock cams, by 4500rpm, ur gonna lag. the lowest i have gain power on they dyno is 4700.
Old May 31, 2004 | 05:44 PM
H22CL's Avatar
5800 rpm
Old May 31, 2004 | 05:54 PM
Shakes's Avatar
space cadet
Default Re: (H22CL)
it was set at 4700. then for some reason the VTEC engagment stoped working and i cant get it right again
i am going to rewire it all when i get back to the states. maybe something fucked up.
Old May 31, 2004 | 10:12 PM
PirateMcFred's Avatar
~4700 for the track
5200 for the street. no need to hit vtec during high(er) speed highway driving.
the Pirate
Old May 31, 2004 | 10:33 PM
Maintenance's Avatar
Default Re: (PirateMcFred)
4500
Old May 31, 2004 | 11:04 PM
patastinky's Avatar
Default Re: (racerxfear)
4688
Old Jun 1, 2004 | 08:28 AM
matix's Avatar
Just installed my vafc. I dropped it too 4800. It engages alot smoother and seems too pull alot harder on my butt dyno.Still needs tuned.
Old Jun 4, 2004 | 01:17 PM
Default Re: (matix)
Quick question:
Is the JDM H22 VTEC engagement point different than the USDM H22?
Old Jun 5, 2004 | 07:51 AM
matix's Avatar
dont know but i know my jdm ecu was 5000
Old Jun 6, 2004 | 08:49 PM
2000sh's Avatar
4500 on my SH... actually gained about 10hp from the 4700 setting...
http://www.preludeonline.com/s...ber=2
Old Jun 7, 2004 | 02:30 AM
94vtirozguy's Avatar
i tested from 3000 rpm to 6000 rpm and it was set to 4870 in the end
