O2 sensor help. P73 or P72 or PR3???
Old Nov 10, 2001 | 07:47 AM
Trey's Avatar
25 Year Member
Default O2 sensor help. P73 or P72 or PR3???
I want to replace both of my O2 sensors and the dealer wants $251 each for the ITR ones. I have a 98 B18c1 with ITR internals, JDM ITR 4-1, and JDM ITR ecu so I thought the P73 O2's is what I'd need. Can I use the P72 ones? I found the P73's at Hparts.com for $166.05 each but really don't want to spend more than $100 each. Anyone know if it really makes a difference which one I use? And any good places to buy them? Is there an aftermarket brand to buy or should I stick to the OEM pieces?
Sorry for all the questions.
Thanks for the help
Old Nov 10, 2001 | 09:05 AM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Default Re: O2 sensor help. P73 or P72 or PR3??? (Trey)
You can use Bosch aftermarket O2 sensor. They go less than $140 at Kragen. You can also use a Civic O2 sensor as long as it's OBD2 4 wired (which I'm using right now and it's used).
If you want use, cheap HONDA OEM/JDM parts, call (800)999-9499 (mon-fri). They are a use parts distributer specifically for ONLY HONDA PARTS and they are located down Rancho Cordova down here in northern cali.
Old Nov 10, 2001 | 09:45 AM
stRtypR25's Avatar
try going to sohfast.com
later bro
diyer
Aug 9, 2004 02:36 PM
clutch33
Aug 4, 2004 03:28 AM
autopc8
Apr 11, 2003 12:35 PM
