Oxygen sensor trouble code...I need help!!!
Old May 30, 2004 | 06:41 AM
djfusion's Avatar
Default Oxygen sensor trouble code...I need help!!!
I am having trouble diagnosing this this oxygen sensor code that keeps appearing on highway drives. I work for a honda shop and have access to the OEM serive manual. I followed the trouble tree as the book tells you and everything passes the test. I have replaced the sensor with and O.E. one, replaced the ecu and still get the code. The trouble code is #1. The o2 sensor is a one wire sensor. When i read the voltage with my volt meter pierced into the wire it doesnt seem to flucuate up and down like i was taught they should. It will flucuate if i blipp the throttle. The voltage it likes to sit at is .7-.850. If im correct this indicates the car is running to rich and the o2 is steadly trying to lean it out right?? Where do i go from here??? thanks...
back2basics
May 25, 2010 05:46 PM
importnoodles
Mar 29, 2008 10:20 AM
B16Civic93
Dec 12, 2006 10:46 AM
SONIC BOOM
Jun 23, 2006 06:40 AM
BeavisB16
Apr 29, 2005 03:57 PM
