Question about front bumper(94 GSR)
yeah there are 2 (3 maybe) that hold the bumper on from the bottom, on the middle black plastic portion of the bumper that extends back around the center jack support thingy
Everything you need to know is on team-integra.net. I don't know if this link will work but here it is... http://www.team-integra.net/se...ID=68 If not just go to http://www.team-integra.net and look for the article about the G3 Front Bumper Removal by Surfer X...its under the Body section I believe. I printed it out and used it to remove my front bumper when I replaced my headlight assemblies. Great info...hope this helps.
1) Top row of plastic-like screws on the top of the bumper that are exposed when the hood is open,
2) Two more 10mm metal screws when the hood is opened on each side of the bumper. In the corner of the engine bay. One should be screwed down. The other should be screwed facing forward.
3) Remove the fender liner. Few plastic screws/clips holding that in.
4) Under the fender, there are two more screws. I don't remember if they are 10mm. One is connecting the fender to the bumper and is screwed in facing the front of the car. The other is right near the fender liner area.
That's it. After that, gently pull the bumper away from the car (forward) and see if there's anything else caught up on it.
Karterguy13
Jan 19, 2005 09:48 PM
