what wires should i use?
Old May 29, 2004 | 09:46 PM
92SiBlu's Avatar
Default what wires should i use?
i have a gsr and i was wondering if anyone knew where to get ngk plug wires that are a bigger gauge? or the part number to them?
Old May 30, 2004 | 08:47 AM
dfoxengr's Avatar
Default Re: what wires should i use? (92SiBlu)
that wont help you. get some stockers
Old Jun 5, 2004 | 05:34 PM
92SiBlu's Avatar
Default Re: what wires should i use? (hybridvteceg)
I just installed NGK blue with denso iridiums what should air/fuel be set at for that and how much fuel (psi)
Old Jun 5, 2004 | 06:57 PM
dfoxengr's Avatar
listen closely. they DONT need more fuel and dont increase hp unless its just becausse your previous ones were old.
Old Jun 5, 2004 | 07:27 PM
Jimmy's Avatar
Global Moderator
I've always used NGK Blues & OEM.
Old Jun 5, 2004 | 08:39 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">listen closely. they DONT need more fuel and dont increase hp unless its just becausse your previous ones were old.</TD></TR></TABLE>
Spend your money else where
Old Jun 12, 2004 | 12:19 AM
92SiBlu's Avatar
Default Re: what wires should i use? (turbogixxer)
Ok... so what you are trying to tell me is that fuel should stay at 35psi warm idle no matter what you have for spark? and did i make a bad choice with the denso? and also would it make any difference if i told you i had a spoon chipped ECU?
Old Jun 12, 2004 | 07:36 AM
LSVTEC 91 Civic's Avatar
Banned
I upgrad from OEM to MSD wires, gave for a smoother ride. Just my .02 cents.
Midori Green
18
May 4, 2007 08:21 AM
2ndGenREX
11
Jan 13, 2007 01:50 PM
Seatown
Jan 10, 2007 08:36 PM
Hondasaurs
Jan 23, 2003 06:26 PM
