How To Tell H22 Intake and Exhaust Cams Apart?
Old May 29, 2004 | 07:33 PM
LudeyKrus's Avatar
Default How To Tell H22 Intake and Exhaust Cams Apart?
How can I tell the difference between my stock intake and exhaust cams?
Old May 29, 2004 | 08:14 PM
v4lu3s's Avatar
RTFM
woudlnt the groove for the distributor drive work?
Old May 29, 2004 | 08:37 PM
LudeyKrus's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">woudlnt the groove for the distributor drive work?</TD></TR></TABLE>
Well the H23 has a groove on each cam, but it also has labels on the cam.
I believe the H22 also has a groove on each end, but I couldn't see any markings; I am trying to know how to tell them apart, w/ the assumption that they both have the dizzy grooves.
Old May 29, 2004 | 10:21 PM
Speedra500's Avatar
Default Re: (LudeyKrus)
im pretty sure the h22 cams dont have the dizzy groove on them, and i dont think the h23 cams do either
Old May 29, 2004 | 10:35 PM
fastludeh22's Avatar
Default Re: (Speedra500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure the h22 cams dont have the dizzy groove on them, and i dont think the h23 cams do either</TD></TR></TABLE>
h22 only on exhaust.
are you sure about h23?
Old May 29, 2004 | 10:47 PM
speedracer9k's Avatar
the h22 exhaust cam has the distributor groove and the intake cam doesn't.
Old May 29, 2004 | 10:49 PM
LudeyKrus's Avatar
Default Re: (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">
are you sure about h23?</TD></TR></TABLE>
Yep; I saw the groove on both H23 cams; that's why i started thinking the H22 had it on both, also.
I shoulda just went and pulled the cam seal off the end and checked it myself........guess I was too lazy. Hmph.
Guess I'll start pokin around in the motor again tomorrow night........
Old May 30, 2004 | 09:52 AM
PirateMcFred's Avatar
I have a H23 set in my garage right now. Both have the distributer notch on the end of the shaft. I noticed that last week when I was looking into H23 regrinds. I figured that I could rekey another Intake cam and have it reground for an exhaust cam. Figured that it might be better for a regrind as an exhaust since his has more material to work with.
My old stock H22 cams though do not have the notch on both. Just the exhaust cam has the notch. another way to tell is to get some calipers and measure the intake vtec lobe vs. the exhaust vtec lobe. the intake is bigger.
the Pirate
preludefien
Apr 2, 2007 08:24 AM
ZXRider
Dec 7, 2006 09:44 AM
beaneg6
Aug 5, 2006 07:05 PM
ATS*Mark
Jan 6, 2004 06:06 PM
