shifter gives off shock
this wouldn't really make any sense, since the brake pedal cover is a rubber, plus if you're wearing shoes... there would be no contact point between the bottom of your foot and the pedal its self. Also, the pedal would have a ground charge to it (or should), and the shifter is also grounded. Even if the +12v wire comming into the plug on the brake switch were to touch the pedal, you wouldn't get shocked because that +12v would be shorted right to ground and either blow a fuse or burn up the wire. Same thing would happen to the shifter. It pretty much has to be static unless something is totally screwed up to the point that you most likely won't be able to figure out.
ahh i found what was wrong, there was once a light up mugen shift **** on the car and the wire was still live inside the shifter
RichFNG
May 10, 2011 09:20 AM
bobobram
Aug 9, 2005 09:25 PM
erikiksaz1
Audio / Security / Video
Apr 21, 2004 09:41 PM
