Ok D16A6 block... Y8 Head.... just clear this up
Old May 29, 2004 | 04:27 PM
Littleredsi's Avatar
Default Ok D16A6 block... Y8 Head.... just clear this up
Alright I tired searching and just keeping find everythign but the answer I am looking for.
So, You can put a Y8 head ona A6 block , right?
A6 pistons wiht Y8 head will yeild a higher CR , right?
their is no problem using A6 block with OBD2, right?
Basically all D16 blocks are the same correct??
Old May 29, 2004 | 04:33 PM
BauleyCivic's Avatar
Risky Business
Default Re: Ok D16A6 block... Y8 Head.... just clear this up (Littleredsi)
Yes
Yes
And Yes
and Yes
Old May 29, 2004 | 05:18 PM
4drEF's Avatar
Keyboard Humorist
A6 block might not have provisions for OBD-2 knock sensor.
Old May 29, 2004 | 07:00 PM
Jaker's Avatar
And unless you swap the oil pump from the OBD2 car, you won't have a crank fluctuation sensor.
Old May 29, 2004 | 11:33 PM
hahagasdcrx's Avatar
Default Re: Ok D16A6 block... Y8 Head.... just clear this up (Jaker)
well you wouldnt need the knock sensor or the crank fluctuation sensor if you were running it in a crx or pre obd civic. It all depends on which ecu your running obd0, obd1,obd2 ( why would you run this?). If you were running obd1 yes you need the knock sensor unless you get your ecu chipped to bypass that sensor.
someone correct me if i am wroung....
Old May 30, 2004 | 02:00 AM
Joseph Davis's Avatar
Default Re: Ok D16A6 block... Y8 Head.... just clear this up (90crxzcgasd)
OBD1 SOHC VTEC do not come with KS, that's the OBD2 shizzle.
Old May 30, 2004 | 10:06 AM
Default Re: Ok D16A6 block... Y8 Head.... just clear this up (J. Davis)
A guy has a A6 block for sale I am looking for a block to build .
It will be used in my 97 Civic. which is OBD2 of course
I just wanted to make sure that everythign woudl be cool wihta A6 block .
THanks
Argentinakidd
May 15, 2018 05:49 PM
Argentinakidd
May 14, 2018 10:05 AM
Ge-money
Mar 18, 2013 03:07 PM
Offer
Oct 7, 2007 09:05 PM
ThaOnlyStunna03
Feb 12, 2004 06:28 PM
