i think i messed up my motor or soemhting not sure...help..
Old May 29, 2004 | 03:48 PM
playboyace35's Avatar
Default i think i messed up my motor or soemhting not sure...help..
i have a broken radiator..last night my car overheat and a lot of smoke start coming out of the engine....radiator fluid was all over my engine bay...ever since that my car when i start it up, it makes a loud engine sound and it rocks back and forth....when i rev it..it's not smooth........what should i do now!?!?1??
Old May 29, 2004 | 05:52 PM
civic_hatchback's Avatar
Default Re: i think i messed up my motor or soemhting not sure...help.. (playboyace35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playboyace35 &raquo;</TD></TR><TR><TD CLASS="quote">i have a broken radiator..last night my car overheat and a lot of smoke start coming out of the engine....radiator fluid was all over my engine bay...ever since that my car when i start it up, it makes a loud engine sound and it rocks back and forth....when i rev it..it's not smooth........what should i do now!?!?1??</TD></TR></TABLE>
Duh, have you fixed your radiator? I was in the car when my bro was going 130 on the highway ( bad idea) and at the time he didnt realize his fan wasnt working.....he took it to a show, turned the car off and radiator fluid went everywhere and started smoking. His fan wasnt working which cause the overheating. Fixed the wires to the fan, fan started working and then the car has been fine ever since. Check if the fan is working and if you havnt fixed the radiator....fix it.
Old May 29, 2004 | 06:01 PM
mmuller's Avatar
Mad Scientist
does it smoke?
sounds like a broken hg
Old May 29, 2004 | 08:12 PM
Default Re: i think i messed up my motor or soemhting not sure...help.. (mmuller)
well i know that my radiator needs to be fixed........is my motor still fine?.......its realli realli loud when its in idle......and when i drive it, it feels like helllla slow
Old May 29, 2004 | 09:00 PM
TeamDOHCside's Avatar
sounds to me like you warped you block and/or head....
Old May 30, 2004 | 08:51 AM
dfoxengr's Avatar
Default Re: i think i messed up my motor or soemhting not sure...help.. (TeamDOHCside)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playboyace35 &raquo;</TD></TR><TR><TD CLASS="quote">......and when i drive it, it feels like helllla slow</TD></TR></TABLE>
dont drive it
Old May 30, 2004 | 09:35 AM
so do i do a leak down test or compression to find out? or both? and if its a blown hs, should i might as well get a vtec head?
Modified by playboyace35 at 7:08 PM 5/30/2004
Old May 30, 2004 | 05:32 PM
96b18c's Avatar
Default Re: i think i messed up my motor or soemhting not sure...help.. (hybridvteceg)
don't rev it either to be listening to the noise, try not to even start it.
Compression test, leak down test, cut oil filter and see if there is any metal particles inside.
Old May 30, 2004 | 08:14 PM
b18cx's Avatar
Default Re: (playboyace35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playboyace35 &raquo;</TD></TR><TR><TD CLASS="quote">so do i do a leak down test or compression to find out? or both? and if its a blown hs, should i might as well get a vtec head?
With your line of questioning, I DO NOT recomend going with the VTEC head. Just take it to your nearest import repair shop.
philibuster
Acura TSX
Mar 25, 2013 09:56 AM
Wthorp
14
Dec 16, 2008 08:29 PM
slayerP
Dec 30, 2007 08:56 AM
RiCE On IcE 2
Nov 30, 2004 12:42 PM
