215/45/16 tires fit on a 99 civic coupe?
what about offset?
I have about a 2.25'' drop with 225/50/15's on 15x7 rota's with 42mm offset. They reb A little on sharp corners or hard braking when turning.
you should be fine. im also running azenis up front, on rota circuit 8's, and have the eiback sportlines( 1.8" drop) on my 98 hatch and they rub a little in hard corners..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSX8600 »</TD></TR><TR><TD CLASS="quote">Just wanted to know if they will clear on my 99 coupe with a drop?</TD></TR></TABLE>
im running eibach sportlines with ukdm itr wheels on my car with that tire format im not getting any problems.
NOW MIND YOU that if you are talking about that tire size and falken azenis you would be running a 220 or 225 width (azenis are wider than a 215) their 205 is 215 width.
Any other tire I dont see why you would have that problem but I would be on the safe side and eliminate any possibility of sidewall flex and get 205's unless you plan on purchasing bridgestone potenza re010's which are made for that format on a 16 inch wheel (thats what im running) and they are quite the expensive tire, no sidewall flex what so ever but the tires imo suck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ichibano »</TD></TR><TR><TD CLASS="quote">They will fit fine. I have 215/45/16 Falken Azenis, and I only rub, a little, at full lock. about 1/4" from tucking.</TD></TR></TABLE>
what size are your wheels? 16x7? or 6 1/2?
