ITR Aluminum A/C Mount
Old May 29, 2004 | 12:44 PM
ej1times's Avatar
Default ITR Aluminum A/C Mount
Well I did a search and found this thread made by "kenji." https://honda-tech.com/zerothread?id=349197
I found it very helpful, but I just wanted to know which belt to use and info. as far as the tension on the belt. Also, if anyone out there has a picture of the A/C mount installed that would be very much appreciated. Thanks
Old May 30, 2004 | 10:44 AM
ej1times's Avatar
Default Re: ITR Aluminum A/C Mount (ej1times)
anyone?
Old May 31, 2004 | 11:59 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej1times &raquo;</TD></TR><TR><TD CLASS="quote">Well I did a search and found this thread made by "kenji." https://honda-tech.com/zerothread?id=349197
I found it very helpful, but I just wanted to know which belt to use and info. as far as the tension on the belt. Also, if anyone out there has a picture of the A/C mount installed that would be very much appreciated. Thanks </TD></TR></TABLE>
I could get you a picture of the installed mount if you really wanted. The belt you use is the same as for a 99 SI. I don't have the part number on hand. Sorry. Also, don't forget that this mount will require tapping of several holes as well as some slight drilling to get it to work.
Old May 31, 2004 | 11:03 PM
ej1times's Avatar
Default Re: ITR Aluminum A/C Mount (Hybrid93Eg)
A picture would be great if it isn't too much trouble.
Old May 31, 2004 | 11:09 PM
Greasemonkey's Avatar
I have a 96 DX and I used the p54 brackett (similar to the Type-R) and I was able to just reuse my old belt no problem when I put my LS motor in there.
Old Jun 2, 2004 | 03:38 PM
ej1times's Avatar
Default Re: (Greasemonkey)
Well, my a/c compressor won't bolt up to the bracket I have. Only one bolt will go through, so that's why I'm going to use the ITR bracket.
Old Jun 3, 2004 | 02:57 PM
Try to find a P54 brackett. It will be much easier to work with
Old Jun 3, 2004 | 05:38 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greasemonkey &raquo;</TD></TR><TR><TD CLASS="quote">Try to find a P54 brackett. It will be much easier to work with</TD></TR></TABLE>
And the reason you made this statement would be??? Its the same ****, only the ITR requires *slight* work and is 5lbs lighter in the end.
Old Jun 3, 2004 | 05:44 PM
ej1times's Avatar
Default Re: (Hybrid93Eg)
Yes. This is why i decided to use the Aluminum Mount. "Hybrid93Eg" would you happen to have that picture of the bracket installed? Thanks.
Hellzone-1000
Aug 19, 2015 09:04 PM
ShinyNewPenny
Aug 9, 2007 06:32 PM
swappedcx
Dec 24, 2005 04:11 AM
dirtracer
Dec 30, 2004 07:16 AM
filtereds0ul
Jul 20, 2003 12:01 AM
