My car idles really low, need help!!!!
I got a 92 hatch with a B18b and I'm running a pr4 ECU from a 93 integra LS. The Car runs perfect, The only problem I got is that when I step on the clutch the car Idles really low and sometimes it even stalls on me. I tried using the GSR ECU but the car runs too lean in the top end ( like at 5k to 7k rpm range) plus the way I drive, I over reved too. But with the GSR ECU when I press the clutch the car idles just fine, unlike the LS ECU. Thanks in advance....
yes I tried that but the problem is only when I step on the clutch, when the car is on Idle it is perfect, it only Idles low when I step on the clutch.....
cl3an_98gsr
Mar 30, 2011 03:10 PM
