3 built B18 blocks/ACT clutch/swaybars/Skunk2/misc parts
Old May 28, 2004 | 08:14 PM
D1703's Avatar
Default 3 built B18 blocks/ACT clutch/swaybars/Skunk2/misc parts
<U>83mm B18B block</U>
-Benson's sleeves (83mm)
-Crower 95mm stroker crank (OEM B20A)
-Crower rods
-JE pistions (13.1 comp)
-JE rings
-OEM bearings/washers
-balanced and blueprinted
-assembled and ready to go
-OEM 83mm gasket by GE
-zero miles, never installed, everything is new
$make offer$
see more pics of the motor here: http://photos.yahoo.com/d1703
<U>81mm B18A Block</U>
-28 pinned around coolant track (like a block guard)
-stock crank
-cleand and hot tanked
-comes with oil pan, pickup, bolts, etc. (Basically everything in the pics in the link)
$300obo
$SOLD
Misc other stuff for sale:
90-91 integra manual OBD0 ECU $60
MSD RPM active swtich (NIB) $40
JDM right side power mirror and switch $SOLD
Del Sol DOHC cluster $SOLD
JDM fuse box $SOLD
Integra center console with JDM armrest pad $80 (on ebay now)
SFC adapter harrness OBD1 $75
Spearco Intercooler with polished ends $300
JDM ITR header heat sheilds (jet-hot coated silver) $SOLD
98-02 Accord carbonfiber hood (has a crack in it) $50
ITR LCA $75
GSR LCA (swaybar holes) $45
AEM ITR cold air intake $SOLD
94 LS complete dist (one leg cut but will include another LS housing) $50
B-series pulleys $45 each (take you pick from the photo)
Honda O2 Sensors $40 each (take you pick from the photo, almost sold out)
Skunk 2 rear sway bar for DC/EG (bar only) $SOLD
Skunk2 lower tie bar with bolts for DC/EG $SOLD
98 LS T/B complete $50
MSD 6AL $80
ACT street disc and HD pp (b-series) $150
Recaro SRD driver seat with OEM rails for DC/EG $SOLD
B-series manual starter $60
See pics here: http://photos.yahoo.com/d1703
Modified by D1703 at 6:18 AM 6/30/2004
Modified by D1703 at 8:58 PM 7/3/2004
Old May 29, 2004 | 04:43 PM
D1703's Avatar
Default Re: 3 built B18 blocks/ACT clutch/swaybars/Skunk2/misc parts (D1703)
up
Old May 29, 2004 | 08:39 PM
1.8LHatch's Avatar
what is the mileage on the clutch?
Old May 30, 2004 | 01:52 AM
D1703's Avatar
Default Re: 3 built B18 blocks/ACT clutch/swaybars/Skunk2/misc parts (1.8LHatch)
like 3200 miles, used for a short time
Old May 31, 2004 | 01:45 AM
D1703's Avatar
up
Old May 31, 2004 | 10:28 AM
gen2integra2001's Avatar
do you still have the B18B block with tha p30 pistons?
Old May 31, 2004 | 11:10 AM
982drLS's Avatar
Default Re: 3 built B18 blocks/ACT clutch/swaybars/Skunk2/misc parts (gen2integra2001)
pm'd
Old May 31, 2004 | 11:20 AM
D1703's Avatar
yes still have everything
Old May 31, 2004 | 08:25 PM
982drLS's Avatar
skunk 2 tie bar sold to me
Old May 31, 2004 | 09:35 PM
The Internet Tough Guy's Avatar
Default Re: 3 built B18 blocks/ACT clutch/swaybars/Skunk2/misc parts (982drLS)
pmed you
Old May 31, 2004 | 10:30 PM
marko_think's Avatar
..bump
Modified by marko_think at 11:44 PM 5/31/2004
Old May 31, 2004 | 11:01 PM
D1703's Avatar
yup skunk2 rear tie bar is sold
Old Jun 1, 2004 | 04:52 PM
D1703's Avatar
up again
Old Jun 2, 2004 | 05:56 PM
D1703's Avatar
somebody buy
Old Jun 3, 2004 | 05:51 PM
D1703's Avatar
up
Old Jun 3, 2004 | 09:04 PM
whatVTEC's Avatar
stock sleeves on the 81mm?
Old Jun 3, 2004 | 09:32 PM
D1703's Avatar
Default Re: 3 built B18 blocks/ACT clutch/swaybars/Skunk2/misc parts (whatVTEC)
yup stock on both except the first block
Old Jun 3, 2004 | 09:42 PM
MugenB16A2's Avatar
what are u looking to get for the 83mm block??? what all is missing???
Old Jun 3, 2004 | 09:44 PM
MugenB16A2's Avatar
How are the Piston to wall clearances????
Is everything according to OEM Specs??? other than the Crower Specs of course, but as far as spacing is concerned...
Old Jun 3, 2004 | 10:35 PM
D1703's Avatar
Default Re: (MugenB16A2)
oem specs, taking offer right now for it. bare short block assembled with pistons and rods.
Old Jun 4, 2004 | 05:54 PM
D1703's Avatar
Default Re: (D1703)
up again
Old Jun 4, 2004 | 06:41 PM
982drLS's Avatar
Default Re: (D1703)
bump for a good seller
bought the skunk 2 lower bar from him , got it today
Old Jun 5, 2004 | 10:20 PM
D1703's Avatar
Default Re: (982drLS)
thanks! up
Old Jun 6, 2004 | 11:20 AM
D1703's Avatar
Default Re: (D1703)
ad is updated!
Old Jun 7, 2004 | 05:52 PM
D1703's Avatar
up
