which to use? MSD 6 or 7 series? LOOK Inside
built h22 turbo, running 880cc's a aeromotive a1000, aem ems..... would a 7al be overkill or do i need it? i dont wanna get somethin too over the top.... im hoping to be in the 550-650 hp range, ive seen it with VERY similar set ups.... just lookin for some info...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H »</TD></TR><TR><TD CLASS="quote">6al, stock coil, stock plug wires made more than 600hp with no problems.
Tyler</TD></TR></TABLE>
Show off.
Show off.
If you plan on doing alot of street driving dont get the 7 series,not really meant for the street.They run too hot under regular stop and go driving and may burn itself out.MSD doesnt recommend it either.
btw..get the digital series of whatever one you go with
very helpful info D-man.... if what u say is correct looks like ill be goin with a 6al... i plan on drivin it on the street a few days a week i think not everyday but alil more than a weekend warrior
You should go with the digital-6,its alot better than the old 6al.
6al
Operating Voltage: +10-18 VDC Negative Ground
Current Requirements: 5 Amps-5,000 RPM
10 Amps-10,000 RPM
RPM Range: 15,000 RPM with 14.4 Volts
Spark Duration: 20° Crankshaft Rotation
Energy Output Max: 105-115 mJ Per Spark
Weight and Size: 3 lbs, 8"Lx4"Wx2.25"H
Voltage Output Max: Primary: 460-480 Volts
Secondary: 45,000 Volts (Blaster Coil )
vs
Digital-6
Operating Voltage: 12-18 volts, neg. ground (Full voltage output down 7 volts supply)
Current Draw: 0.7 amp per 1,000 rpm (7.2 amp)
with 14V bat.@ 10,000 rpm
RPM Range: 12,500 rpm with 14.4 volt supply
Spark Duration: 20° crankshaft rotation thru 3,300 rpm
Spark Energy: 135 milliJoules per spark
Weight and Size: 3.7 lbs, 8.5"L x 4.5"W x 2.2"H
Voltage Output Max: Primary: 535 Volts delivered to coil
Secondary: 45,000 Volts (MSD HVC Coil)
Modified by D-Man at 8:12 PM 5/30/2004
6al
10 Amps-10,000 RPM
vs
Digital-6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man »</TD></TR><TR><TD CLASS="quote">If you plan on doing alot of street driving dont get the 7 series,not really meant for the street.They run too hot under regular stop and go driving and may burn itself out.MSD doesnt recommend it either.
yup exactly what he said i got a couple fried boxes i went through threw the years 7al on street is a no.no
p.s try bigger injectors
</TD></TR></TABLE>yup exactly what he said i got a couple fried boxes i went through threw the years 7al on street is a no.no
your pushing it with 650 hp if you drive the car at nite with lites on and drawing lots of power from the pump that aeromotive draws a lot of amps,atleast thats what i noticed with my pump and 1000cc injectors
ok lets refresh.... i will be driving the car at night alot . . . im gonna try not to drive it any long distances.. ( over an hour? ) i do however have a small NRG_cell battery (heel-toe) i wont have any crazy sound system.. a deck and 2 door speakers.. thats it... i was also considering hooking the alternator to a switch, someone gave me the idea and it sounded pretty good but i havent looked into it... (shut the alt off during a quick drag, then switching it back on?) . .
turning alt off hmmm, i know that 7a needs constant 14 volts or it dont work......i said the same thing bout the 7al "ill only be driving short distance no wippers no system blah blah " long story short i spent a lot of money on 7a"s
and towing
and towing
alt would only be off for under a minute, like i said just to get every ounce of power for the drag then switch it back on. . . idk just somethin someone was tellin me and they made it sound like id get decent power if the motor didnt need to power the alt
extremmly minimal i had acouple full race mustangs back in the day and had no alt. at all, strick track and one pass street runs and that was such a pain in the @$$ ya got to stay by the car each round with a battery charger so no one steals it
and if the 7a didnt have full power .....nada car ran like ****
yea i doubt ill do that , but ill end up goin with the 6 series... and if i have EMS that will control 2step so do i even need the digital? ill prolly get the digi anyway. .
A train
Apr 3, 2008 11:28 PM
Integrity_On_Wheels
Oct 13, 2005 11:01 AM
