cam shaft journals on an 89 prelude si (DOHC)
Old May 28, 2004 | 01:36 PM
hondainspired's Avatar
Default cam shaft journals on an 89 prelude si (DOHC)
i've got all the bolts loosened.. i just can't for the life of me remember the little "trick" to get the journals (or caps maybe) off the camshafts... without ******* them up that is....
Old May 28, 2004 | 07:56 PM
DW's Avatar
DW
Default Re: cam shaft journals on an 89 prelude si (hondainspired)
if you can't wiggle them off with your fingers then get a small flathead screwdriver and LIGHTLY pry them off a little at a time on both sides. they have little dowel pins that hold them in there so they can be stubborn sometimes. just make sure you don't make any scares on the head or cam.
hth,
David
Old May 29, 2004 | 10:36 AM
Default Re: cam shaft journals on an 89 prelude si (DW)
ok cool thank you very much.... first rebuild... i am confident i can do it ... i just dont want to run into anyproblems ANYWHERE so i'm being patient and cautious
Old May 29, 2004 | 03:13 PM
DW's Avatar
DW
no problem, post back if you have any more ?'s. i have some experience with the 3rd gen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondainspired &raquo;</TD></TR><TR><TD CLASS="quote">i'm being patient and cautious</TD></TR></TABLE>
this is key
David
Old May 29, 2004 | 03:19 PM
Speedra500's Avatar
what i do for the caps is get a thin rag and some vice grips and wiggle them off
Madrek
Jul 25, 2007 10:33 AM
EJ8 GSR-T
May 18, 2006 02:38 PM
asubennett
15
Jul 9, 2005 03:05 PM
alacorn101
13
Feb 19, 2005 07:54 PM
krnboixshawn
Jun 28, 2003 09:36 PM
