starter wont turn motor
Old May 28, 2004 | 01:35 PM
MUGENKHID's Avatar
Default starter wont turn motor
me and a friend were workin on his crx. juss had to bolt the tranny on put in a front axle and put on the tires. his dad said he had eveything else done. so we go out nd do all of this, go to start it, and it doesnt sound like the starter is engaging the flywheel. we look and it isnt bolted on all the way. we tightened it up and now its makin a little different sound so i think its engagin he flywheel but not the motor, cuz the motor doesnt even try to turn over. the starter is brand new. could it have been messed up from tryin to start it without bein all the way bolted on? if not whats wrong?
Old May 28, 2004 | 01:48 PM
4drEF's Avatar
Keyboard Humorist
Default Re: starter wont turn motor (MUGENKHID)
If you had it out a bit and it didn't engage the flywheel then it would make a high pitch "wizzzzzzzzzz" sound.
When it engages the motor turns over.
Maybe the battery you are using low and needs a jump or a good charging?
Old May 28, 2004 | 04:09 PM
MUGENKHID's Avatar
Default Re: starter wont turn motor (4drEF)
it made the high pitch "whizz" sound but once we tighten it it was still a 'whizz" sound juss not as high pitched. but ill try a jump.
Old May 28, 2004 | 04:11 PM
kylefakesi-r's Avatar
slide it back off and make sure you didn't just chew all of the teeth off of it.
TylerC161
Dec 29, 2007 11:21 PM
hndacord02
Dec 18, 2007 09:51 PM
Kimbo
Dec 2, 2005 05:32 PM
Paste
Sep 20, 2004 01:18 PM
cstay
May 14, 2004 06:30 PM
