VAFC Install on Type R...Help with Pressure and VTM wire...PLEASE HELP
I just installed my VAFC
I have a 2001 ITR
I am not getting a reading from the Pressure sensor on the VAFC sensor check screen
I am using the Blu/Blk at C10
I check all my connections over and over with a multimeter using continuity test they are fine
If this is not the correct wire
Can someone help me locate the pressure wire on the ECU
Also I did not hook up the VTM wire can this be my problem what did you guys do with the VTM wire on your ITR install
Someone please help me If you have a helms or know from installing your VAFC
I am in a bind and i dont know where to turn
Help is greatly appericated
I have a 2001 ITR
hey,this is danny from radio active.the pressure wire is white/yel.it is in the smaller grey plug that is oposite the firewall.the vtm wire is the blue/black wire.you can call me at the shop tommorow if you still need help.
p.s.you can go to their web page and get an ecu layout and owners manual.it is very helpful.
[Modified by turbotypeR, 7:31 PM 11/9/2001]
Make sure that you plug in the vtm wire.Even though the instructions tell you not to, do it.When I first had mine installed, the vtm wire wasn't connected and it threw me into limp mode. I couldn't go past 5 and I was pretty pissed off.GRRRRRRRRR....*Sigh* At least I found out what the problem was....Anyways....hope that helps a little
Hey thanks alot
I will try this ASAP
Let u's know how it goes
Hey danny i dont know the number to your shop anyways !!
Thanks for the invitaion though -- ill let u know if i have any further trouble
Thanks soo much again
NeXtLeVeL_TyPe_R
Nov 10, 2001 07:11 AM
