How did you mount your battery? PICS
Old May 28, 2004 | 10:04 AM
AllMotoRex's Avatar
Default How did you mount your battery? PICS
Can those of you that have aftermarket batteries and or relocation kits post pics of your engine or wherever it is that you mounted ur battery? I"m having trouble decinding where to mount my NRGCell batt. i was thinking samw spot as OE but i just tied it with rope(ghetto rig) for now til i figure out how to mount it better.
ANY IDEAS? !
Old May 28, 2004 | 10:16 AM
EF_LSVtec's Avatar
Default Re: How did you mount your battery? PICS (AllMotoRex)
Old May 28, 2004 | 10:33 AM
I3ackfire's Avatar
Default Re: How did you mount your battery? PICS (EF_LSVtec)
Is that a good idea to have your battery right next to your intake that close???
I would like to know more about your LSVTEC could you PM me!
Old May 28, 2004 | 10:37 AM
Mr_CRX's Avatar
This isnt mine, but I found it when I was looking for ideas a while back..
Old May 28, 2004 | 11:11 AM
EF_LSVtec's Avatar
Default Re: How did you mount your battery? PICS (I3ackfire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ackfire &raquo;</TD></TR><TR><TD CLASS="quote">Is that a good idea to have your battery right next to your intake that close???
I would like to know more about your LSVTEC could you PM me!</TD></TR></TABLE>
Why not?
Old May 28, 2004 | 11:16 AM
I3ackfire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">
Why not? </TD></TR></TABLE>
I dont know, I was just asking?
Old May 28, 2004 | 11:23 AM
AllMotoRex's Avatar
ITs okay to have the battery that close to the intake thats how it comes from factory.. well close wise..
BTW thanks for the pics.. that how i have mine right now but its roped.LOL, i was going to use the stock brackets but they are too long so i bent them to make em shorter but there is no room for the bent part on the underside so it wont go in all the way.. guess i'll make my own custom one like ur .. thanks EF_LsVtec~
Old May 28, 2004 | 11:40 AM
primeredbeast's Avatar
i got the small battery from thunderstrike or whatever it is motorsports and works great clears all charge piping and starts the car up everytime
Old May 28, 2004 | 12:43 PM
FourthGenHatch's Avatar
Old May 28, 2004 | 12:58 PM
EF_LSVtec's Avatar
No problem...I bought my raw materials from my local hardware store...except had a friend cut and weld em for me. I'm sure you can get aluminum bars that would work as good
Old May 28, 2004 | 02:27 PM
kylefakesi-r's Avatar
Default Re: How did you mount your battery? PICS (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
i would post a pic of mine but it is identical to this with a yellow top and a white floor pan.
soon to be replaced by a sealed box so i can pass tech inspections though.
Old May 28, 2004 | 02:47 PM
AllMotoRex's Avatar
We think alike.. on the aluminum part especially. .want to keep the weight down .. part of the reason i got the battery, dont corrode.... at first I even thought about mounting it on the firewall like the DC's and Ek's. but then noticed there isnt much room!
Old May 28, 2004 | 02:52 PM
mount it behind the passenger seat. there is a series of plastic clips that happen to hold 2g battery cable nicely and snugly under teh carpet shell. just use on of the seat rail lugs to ground to and fee the cable up throught the grommet ont he firewall that the ecu connectors comethrough.
Old May 28, 2004 | 03:40 PM
dingusjt's Avatar
Default Re: How did you mount your battery? PICS (kylefakesi-r)
here you go
and hey you can buy this whole battery setup for only $70 from me!! yeah thread jack!
Old May 28, 2004 | 03:54 PM
Garrett's Avatar
Default Re: How did you mount your battery? PICS (dingusjt)
Old May 29, 2004 | 04:04 AM
NCchris's Avatar
I did mine like this article:
http://crx.honda-perf.org/arti....html
If you look under the panel right beside the small "personal" storage compartment, my 90 HF has a welded in tab with a welded on 7/16-20 (SAE) nut. This was not used but was aparently for seatbelt ancor because of the sae thread. Anyway, this makes a super ground lug.
HTH
chris
Old May 29, 2004 | 07:22 AM
b16_madman's Avatar
Default Re: How did you mount your battery? PICS (NCchris)
i gotta get around to makin a battery box from work out of sheet metal or aluminum
Old May 31, 2004 | 08:05 AM
AllMotoRex's Avatar
Hey wasnt that on Ebay??? I put ur post on H-T , thought i'd try and help you out! lol
https://honda-tech.com/zerothread?id=871048
Old May 31, 2004 | 09:47 AM
I'll cut ya!'s Avatar
FYI You can use a tractor battery from home depot to run your car. Its similar to these slim line batteries (well, its about half the size of a standard battery), and only about $40
Old Jun 1, 2004 | 10:25 AM
AllMotoRex's Avatar
Default Re: How did you mount your battery? PICS (I'll cut ya!)
Good to know.. is it a drycell batter as well?
To those of you that have relocated the battery : Does your car now take a second extra to start? or is it the same?
Old Jun 1, 2004 | 10:28 AM
EF_LSVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotoRex &raquo;</TD></TR><TR><TD CLASS="quote">Good to know.. is it a drycell batter as well?
To those of you that have relocated the battery : Does your car now take a second extra to start? or is it the same? </TD></TR></TABLE>
Yes it does but it didnt a year ago when battery was quite new.
Old Jun 1, 2004 | 11:50 AM
DXDOHCVTEC's Avatar
Mine is in the hatch next to the spare tire, and I made my own tie down for it. Works well.
Old Jun 1, 2004 | 12:08 PM
8 9 si's Avatar
Since we are at the same topic, can I ask where did you get those braket from? Hard-ware store, Home Depot? Lowe's? Also, I have an Viper alarm on mine, and I just put the Odyssey batt on it. Does the alarm going to drain all the juice from the cell gel battery? Thank you
Old Jun 1, 2004 | 12:11 PM
DXDOHCVTEC's Avatar
My bracket is made of two 16" threaded rods and a flat piece of billit aluminum rod that I cut to proper size also some washers and nuts to hold everything in place. All of this was from Home Depot.
Old Jun 1, 2004 | 12:14 PM
MADEINIRAQ's Avatar
Default Re: (DXDOHCVTEC)
