clutch judder
Hi guys..
I've been having this problem recently went I'm pulling off in first gear. When I put the clutch down there's a funny noise like metalic sounding. When I try to pull off the car judders, but if I use more revs then it's not as bad. I am pretty sure that the clutch is on it's way out but would just like to comfired it with you geniuses..
Oh and what website can I get an ACT clutch kit from? I need it imported to London, United Kingdom..
Thanks
Thanks
My prelude just started doing this too...I asked my mechanic and he said the flywheel might be warped??? I dont know if thats true but Im changing clutch and flywheel in the next few weeks anyways just incase.
could also be something on the clutch such as oil... Or it could be busted springs on the disk. Unless you have an aftermarket racing clutch then it could just be because of that. Some racing clutches will do this.
It's an OEM clutch. Its been going for a while but it's been getting pretty bad lately.
I'm getting a new clutch and I'm not too sure which to get.
Either the ACT HDSS or Exedy oganic stage 1..
Which is recommended as a daily driver with hard launching on the strip??
