b20 CRV timing belt and b18b1 timing belt same part number?
Old May 28, 2004 | 08:27 AM
EKB18BPR3's Avatar
Default b20 CRV timing belt and b18b1 timing belt same part number?
my timing belt broke yesterday on my b18b1. thats not my problem. the problem is...the nearest acura dealer is 2 hours away and the honda dealer is 20 minutes away. i went to honda dealer to order b18b1 timing belt and so they called up acura and acura said crv timing belt will fit my integra ls motor. can anyone varify this before i tear the bag open and install it?
Old May 28, 2004 | 01:35 PM
EKB18BPR3's Avatar
Default Re: b20 CRV timing belt and b18b1 timing belt same part number? (98B00STED)
anybody know?
Old May 28, 2004 | 03:28 PM
boostinb20vtec's Avatar
should be, it's the same motor besides the bore.
Old May 28, 2004 | 03:42 PM
I Shot 50 Cent's Avatar
try http://www.acuraautomotiveparts.org they should have it for order cheap, as well as the part number, compare it to the B20
Old May 28, 2004 | 04:54 PM
Kaneo's Avatar
Default Re: (R81DC2LS)
They are the same i have my b18b belt on b20.
Old Jun 1, 2004 | 09:28 AM
G.B.HONDAPARTS's Avatar
The B18 and the B20 use the same part number timing belt (14400-P7J-004). There should also be a number on the belt indicating the size. For instance, the B18 and B20 belt is a 126RU26 which means it has 126 teeth and is 26mm. wide. Hope that helps.
SolAssassin
14
Oct 2, 2009 03:09 PM
5lugcivic
Nov 19, 2007 02:01 PM
EKB18BPR3
Jun 3, 2004 06:55 PM
hondeducation
Feb 5, 2004 11:56 AM
