fan speed resistor pack
If you remove your glove box, there should be something going into the heater ducting with a connector going into it. It is small and about 1"x0.5" when viewed from the back. If I remember correctly, it is held in by two screws. Take it out and you will see that the resistor pack consists of a bunch of exposed coiled wires. Chances are that either some crap is on it or the wires are touching each other; this affects the resistance read by the pack which affects the fan speed. If you clean off the debris and/or untangle the wires, this may solve your problem. If not, substitute one from a friend's Civic/Integra and see if that solves it. Good luck.
