MPFI ? have searched please help
You're gonna need a bypass coolant hose, it's a U-bend (the DX mani is a different shape and will kink if you try to use it). Your local autostore should have it. I got mine at Checker Autoparts.
From: I told you to wait in the truck in Texas, United States
look here by the thermostat housing:
http://www.binghamtonlife.com/...3.jpg
for mpfi links,look in the FAQ section at the top of this forum..
https://honda-tech.com/zerothread?id=637661
yes you'll need the 180 degree coolant line as mentioned
you might also want to pick up a new pcv valve for the mani your using.. i ghetto rigged my car with the dx one but they're cheap so you might as well do it right.
malubawla
Northeast (Sales)
Jan 17, 2007 10:40 AM
