Wiring up JDM Guage Cluster--difficult?
Old May 28, 2004 | 06:20 AM
SLICK96's Avatar
New User
Default Wiring up JDM Guage Cluster--difficult?
I just bought a 91 EF hatch, and I want to install the JDM guage cluster from, say, and SiR EF. What's the difficulty in this? From the pics I've seen of the guage clusters, it doesn't seem plug & play. Are the USDM EFs prewired for things like the tach that the JDM SiR cluster has? Anything else I should know?
J
Old May 28, 2004 | 06:42 AM
Footwork's Avatar
Default Re: Wiring up JDM Guage Cluster--difficult? (SLICK96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLICK96 &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a 91 EF hatch, and I want to install the JDM guage cluster from, say, and SiR EF. What's the difficulty in this? From the pics I've seen of the guage clusters, it doesn't seem plug & play. Are the USDM EFs prewired for things like the tach that the JDM SiR cluster has? Anything else I should know?
J</TD></TR></TABLE>
the jdm ef9 cluster is basically obd1.
so you would need to convert your b series 91 hatch to obd1 for the cluster to work.
Old May 28, 2004 | 06:47 AM
EF_LSVtec's Avatar
Default Re: Wiring up JDM Guage Cluster--difficult? (Primo.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Primo. &raquo;</TD></TR><TR><TD CLASS="quote">
so you would need to convert your b series 91 hatch to obd1 for the cluster to work.</TD></TR></TABLE>
Please, if you do not know what you're talking about, I'd keep my comments myself
Anyway, Cluster swap is not that difficult. Scale from 1 to 10, I'd say a 6. I suggest getting a pin tool (paper clip will do) for cleaner transfer of wires although you have to extend a couple of wires for better fitment. I don't have the instructions off hand but pm me later in the day (this evening) or I'll post em when I get home. btw, you need and electronic VSS to make this work and you definitely do not have to convert to obd1
Old May 28, 2004 | 08:33 AM
90civichbsi's Avatar
i did the swap as well, just make sure your getting a good electronic vss, i went through 2 b4 i got a good one.
and the reason for doing the swap is for one to have a better looking cluster, and the main reason to have a cluster that hasa redline of 8K like for b16 swaps
heres a writeup:
http://b16a.honda-perf.org/cluster.html
id reccomend getting some paste solder and heat shrink tubing so you dont have alot of tape behind your cluster
Old May 28, 2004 | 08:45 AM
Footwork's Avatar
Default Re: Wiring up JDM Guage Cluster--difficult? (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">the main reason to have a cluster that has a redline of 8K like for b16 swaps</TD></TR></TABLE>
cool write up/link.
p.s. anyone want to buy my jdm ef9 cluster?
Uniquerootz
Oct 3, 2007 06:42 AM
killacrx1
Apr 1, 2007 10:17 PM
irtep
15
Dec 22, 2002 10:29 PM
spcmotorsports
Aug 27, 2002 08:09 PM
