SRS LIGHT/ ABS LIGHT - Help Please.
Old May 28, 2004 | 01:20 AM
BoostedVtecGsr's Avatar
Default SRS LIGHT/ ABS LIGHT - Help Please.
i was needing some help/ info..
i was changing my rear passenger side tail light bulb... and was having some problems with it.. (turn signal bulb.. wouldn't turn on with the new bulb..) unless i messed with it by twisting it around.... i couldnt figure it out... but then all of a suden my gauges and whole speedometer wouldnt work.... followed by a srs light... .. and this all happend from messing/changing out the tail light bulb.... i finally figured out that it was a fuse under the hood... so now the signal light works fine , but my srs light is still on.... can anyone help me figure out whats wrong or how to reset it.. i would greatly appreciate it.
My abs light is also on.... after doing a motor swap... i've checked all the connectors and harnesses... everything seems to be intact...... what other problems could cause this ???
thankyou for all those helping.
samyd25
Nov 14, 2013 02:42 PM
William1991b
Sep 8, 2011 05:19 AM
wardseg6
Honda Civic (2001 - 2005)
Jul 21, 2007 11:40 PM
