H22 converted to OBD 1 - What ECU are you using?
Old May 27, 2004 | 08:11 PM
uncle's Avatar
Default H22 converted to OBD 1 - What ECU are you using?
For those that have done the OBD 2 - OBD 1 conversion: What ECU are you running and did you swap out the saturated injectors or leave them in?
I am asking because I recently swapped out my y8 for an h22, converted to OBD 1 but left the saturated injectors in. I am running a p13 and it doesn't seem like I am getting the power I should out of the motor. I am thinking of giving the 345cc's a try despite everyone saying it should run fine with them in.
Old May 28, 2004 | 09:28 AM
uncle's Avatar
Default Re: H22 converted to OBD 1 - What ECU are you using? (uncle)
Is anyone using a p13 with the saturated injectors?
on-site ej1
Dec 15, 2008 08:08 AM
PremiumPrelude
Mar 12, 2008 01:25 PM
civic nation
Sep 3, 2006 05:01 PM
turbo boost
20
Aug 14, 2005 05:20 PM
