brake master cylinder got empty while bleeding brakes...
Old May 27, 2004 | 07:06 PM
dng's Avatar
dng
Default brake master cylinder got empty while bleeding brakes...
will i need to bench bleed the mc before continuing to bleed the 4 corners?
Old May 27, 2004 | 08:55 PM
mmuller's Avatar
Mad Scientist
Default Re: brake master cylinder got empty while bleeding brakes... (dng)
i would advice so.. or it might take you forever to bleed them properly
Old Jun 6, 2004 | 07:28 AM
Bizarre's Avatar
The same problem happen to me. I did my brakes and didn't notice the MC going low when bleeding. Not sure if it went empty, but when I brake the pedal basically sinks all the way to the floor. And when bleeding at the calipers, no air comes out. How exactly do you bench bleed the MC? Does it require removing the MC from the car? If so, is there a way to do it in the car?Thanks
Modified by Bizarre at 12:50 PM 6/6/2004
Old Jun 7, 2004 | 05:16 AM
JimBlake's Avatar
Default Re: (Bizarre)
I've let the reservoir go empty, didn't bench-bleed, simply took longer to get all the air out. It seems like you get NO air for a long while in the back, then finally you get a few bubbles out. I think I used 2 quarts of fluid (total) that time.
You should be able to bench-bleed in the car. Disconnect the brake lines from the MC. Install tubes or brake lines that loop upwards & pour back into the reservoir. Pump the brake pedal like that for a while until there's no more air in the MC. Then reconnect the real brake lines & bleed the calipers.
Old Jun 19, 2005 | 03:31 PM
DC2-JRSC'd's Avatar
Default Re: (JimBlake)
back from the dead but the same happened to me too. so i tried to bleed the brakes until i get all the fluid out. i think i went through 5-6 master cylinder refills and i still didnt get any air out of the rear lines. do i need to go longer then that?
Old Jul 3, 2005 | 01:33 PM
STN_Pat's Avatar
Default Re: (DC2-JRSC'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2-JRSC’d &raquo;</TD></TR><TR><TD CLASS="quote">back from the dead but the same happened to me too. so i tried to bleed the brakes until i get all the fluid out. i think i went through 5-6 master cylinder refills and i still didnt get any air out of the rear lines. do i need to go longer then that?</TD></TR></TABLE>
How does the pedal feel ?
Old Jul 3, 2005 | 09:24 PM
DC2-JRSC'd's Avatar
Default Re: (STN_Pat)
i fixed it a while back, i had to bleed the MC first and then the lines.
jwlee7ucla
Apr 14, 2024 07:41 AM
dgdarien
Sep 25, 2009 06:25 PM
jwrape
May 25, 2008 01:33 PM
DriveSlowHomie
Jan 31, 2008 03:14 AM
GSR95T
Sep 4, 2002 09:21 AM
