camber kit necessary for 1.5 inch drop w/tien springs?
Old May 27, 2004 | 05:22 PM
vannman's Avatar
Default camber kit necessary for 1.5 inch drop w/tien springs?
is a front or even rear camber kit even worth it for a 1.5 inch drop on a 98 lude? I have tien springs w/stock shocks and was wondering if i should even worry about a camber kit to prevent uneven excessive wear on my tires? should i just have my toe alighned and leave it and hope my tires don't wear fast? just wondering.. i am new to the prelude world.. on my 2001 celica gts it had adjustable camber as stock.. pretty neat.. oh well i have a lude now.
Old May 27, 2004 | 05:29 PM
equinox's Avatar
Default Re: camber kit necessary for 1.5 inch drop w/tien springs? (vannman)
First of all, congratulations on your purchase of the prelude, it's much more powerful than the GTS .
I got the TEIN s-tech springs (1.5'' drop) two months ago on my 5th gen prelude and my tires are still great. My alignment is also still good so no wheel alignment and camber kits should be necessary.
Old May 27, 2004 | 05:45 PM
bRiGgA4U69's Avatar
Default Re: camber kit necessary for 1.5 inch drop w/tien springs? (lude_roller)
lude_roller, do you have pics of your drop? let me know
thanks
iCk
Old May 27, 2004 | 06:06 PM
LudeyKrus's Avatar
I was on a 1.75/1.5 drop for a while, and my tires were fine. I would say get a set if you have the cash, but don't worry about it if you don't.
Old May 29, 2004 | 10:19 AM
bRiGgA4U69's Avatar
my email is mohammi@cc.wwu.edu
I can't use the IM feature as i am a trial user. how do i become a normal user. thanks in advance for the pics
iCk
Old May 29, 2004 | 11:00 AM
Kal's Avatar
Kal
Default Re: (bRiGgA4U69)
it takes a time period. the trial period prevents people from just joining the board and going on to buy/sell stuff and then just leaving.
Old May 29, 2004 | 10:22 PM
lOOkatme's Avatar
remember to get an alignment after you lower your prelude. most people skip out on the alingment and blame their shitty tire wear on bad camber....when in reality its bad toe that just ate through their tires.
Old Jun 1, 2004 | 03:32 PM
equinox's Avatar
Default Re: (lOOkatme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lOOkatme &raquo;</TD></TR><TR><TD CLASS="quote">remember to get an alignment after you lower your prelude. most people skip out on the alingment and blame their shitty tire wear on bad camber....when in reality its bad toe that just ate through their tires.</TD></TR></TABLE>
It would be better if you get your wheels aligned, that is if you have money layin around needing to be spent. It really isn't necessary for only a 1.5'' drop
Old Jun 1, 2004 | 03:41 PM
Inextricabledrvr's Avatar
Default Re: (lude_roller)
i wanted to ask you guys if the koni yellows would work with the TEIN springs?
I know only certain applications will work with these shocks. The reason i ask is that i have a SH and they are a pain to find parts for. I even called koni persoanlly and they werent even certain if they would fit. The ones that they could guarantee were the neuspeed sports on the SH.
The reason being that they had compensated for the longer spring that the Sh has over the base model. I suppose that the SH has an extra coil on the bottom?
Im not sure, but if anybody knows about this or if the TEIN springs will work with the Koni yellow adjustables please let me know.
sorry i kinda got off the topic.
thanks
Old Jun 1, 2004 | 05:31 PM
SKDRCR's Avatar
Default Re: (Inextricabledrvr)
you should upgrade your stock shocks if you have lowering springs,
they're gonna wear out quick if you don't.
you should definately try to get an alignment and if they can't get
it aligned you'll probably need a camber kit
Old Jun 1, 2004 | 08:51 PM
lOOkatme's Avatar
what are you talking about? its a MUST to get an alignment after lowering the car...regardless of drop.
if you take the stock springs out and put them back on....alignment is needed.
Old Jun 2, 2004 | 05:39 AM
dc5r2002's Avatar
just remember that every inch you go your camber goes 2 degrees negative, but hell what would I know i have only lowered 2 or 3..............hundred cars anthing over 3 degrees negative camber your gonna have poor inside tire wear, you need to decide are you lowering for looks or performance
Old Jun 2, 2004 | 06:48 AM
bad-monkey's Avatar
Default Re: (Pulp Fiction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pulp Fiction &raquo;</TD></TR><TR><TD CLASS="quote">just remember that every inch you go your camber goes 2 degrees negative, but hell what would I know i have only lowered 2 or 3..............hundred cars anthing over 3 degrees negative camber your gonna have poor inside tire wear, you need to decide are you lowering for looks or performance</TD></TR></TABLE>
negative camber is good for performance though...
on a 1.5" drop i don't think a camber kit is necessary. the tire wear won't be bad so long as you zero out the toe, so get an alignment. you definitely need new shocks. may wanna call koni and see if their shocks work with tein springs, but i think the konis probably have adapter hardware to make them work.
Old Jun 2, 2004 | 09:31 AM
dc5r2002's Avatar
Default Re: (bad-monkey)
right negative camber is good for performance, but if you are driving the car everyday and have excessive negative camber your going to have to buy new tires every 6 months. the camber kit is good for a daily driven vehicle, you can adjust when you want the performance. also having too much negative camber will affect other parts like the wheel bearings, all sorts of noises will begin sometimes you lower a car and the noises never go away, you have to do it right, call the companys, dont belive what anyone tells you, do you think you would want someone to know you dropped a load of cash into your suspension and it handles great but eats your tires to hell
and yes i would go for the camber kit on the drop 1.5"=3degrees negative camber + what your stock camber spec is
Old Jun 2, 2004 | 09:35 AM
del_parker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pulp Fiction &raquo;</TD></TR><TR><TD CLASS="quote">right negative camber is good for performance, but if you are driving the car everyday and have excessive negative camber your going to have to buy new tires every 6 months. </TD></TR></TABLE>
my tires wear out in 6 months if i have zero camber... might as well make the most of it.
Old Jun 2, 2004 | 10:48 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pulp Fiction &raquo;</TD></TR><TR><TD CLASS="quote">right negative camber is good for performance, but if you are driving the car everyday and have excessive negative camber your going to have to buy new tires every 6 months. the camber kit is good for a daily driven vehicle, you can adjust when you want the performance. also having too much negative camber will affect other parts like the wheel bearings, all sorts of noises will begin sometimes you lower a car and the noises never go away, you have to do it right, call the companys, dont belive what anyone tells you, do you think you would want someone to know you dropped a load of cash into your suspension and it handles great but eats your tires to hell
and yes i would go for the camber kit on the drop 1.5"=3degrees negative camber + what your stock camber spec is</TD></TR></TABLE>
having 5 degrees of negative camber is probably not a good thing, but the camber on a 1.5" drop will be more in the neighborhood of ~1.5-2 degrees, if i'm not mistaken. that isn't too bad. the tires won't die in 6 months on -2 degrees of camber (unless you drive a lot in that period of time.)
if it was me, i'd get a camber kit for sure, but i don't think it's an absolute necessity.
Old Jun 2, 2004 | 11:15 AM
99silprelude's Avatar
yeah, since I lowered my car using the eibach pro kit springs the negative camber ate the inside of the tires much faster, but then again that was w/ the 18" rims on. Now I have the stock alloys back on and so far the camber hasn't affected them much
Old Jun 2, 2004 | 01:34 PM
lOOkatme's Avatar
What kind of BS is this.
I have lowered many vehicles myself. My car is lowered roughly 1.3-1.5 inches or so on tein SS coilovers. My printout from my alignment is -1 degrees front and -.5 rear.
That totally contridicts your theory. Your theory is complete and utter BS. I have one example of my ride with a personal experience....AND MANY MANY others on these boards.
From my knowledge....working with about 5 preludes on lowering. I would say the degree change would be more like this.
1.5 inch drop is between -1 to -1.5 degree negative camber for the front. the rear seems to vary more. 2 inch drop will get you closer to the -2 degree camber.
having -1 or -1.5 degree camber won't eat through tires. Moreover, it will help handling.
Like I will say again. I'd put money on these people wearing out tires due to bad <FONT SIZE="4">TOE</FONT> than camber. Most people drop the car and never get an alignment done after the drop. they visuaully see the bad wear on the tire...assume its camber....get an alignment done...and its all good. But in reality...it would have been just fine without the camber kit and aligning the toe in/out.
I made the mistake of this...and I am sure many others have too. I thought it was bad camber....when it was bad toe. There are no good front camber kits on preludes.....even the SPC (I had it) will hit the top upper mount on big bumps. I suggest picking a drop around 1.5 (which is street drivable 2inch drop isn't) and sticking with it without a camber kit. this comes from me...a person who experiences sooo many damn lowering springs and coilovers that I should be deemd drop pro.
My set ups in the past.
neuspeed sport springs on stock shocks (fine tire wear)
H&R race with KYB agx adj shocks (fine wear with camber kit, camber kit hit upper mounts cause it sticks above upper control arm (nut))
SKunk2 coilovers (suck ***....fine tire wear though)
Tein SS coilovers. (fine tire wear at 1.5" drop...cornerweighted)
Old Jun 2, 2004 | 07:20 PM
H22Power_521's Avatar
^^^ i agree
i have neuspeed sport springs... 1.75 front and 1.5 rear.
i just got an alignment printout a few days ago and i have -1.3 front and -1.5 rear. that -2 degrees per inch dropped is bs.
Old Jun 3, 2004 | 07:32 AM
dc5r2002's Avatar
Default Re: (H22Power_521)
yeap your right and im wrong if thats what you want to think.
Old Jun 3, 2004 | 09:06 AM
lOOkatme's Avatar
Yea...most people who are dropped 2.25" on race springs have -4.5° camber
Maybe -2 or -2.5
Old Jun 3, 2004 | 01:30 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lOOkatme &raquo;</TD></TR><TR><TD CLASS="quote">Yea...most people who are dropped 2.25" on race springs have -4.5° camber
Maybe -2 or -2.5</TD></TR></TABLE>
his theory may be right, in that the stock suspension has slightly positive camber. it's definitely not 0 camber. whether it's positive .5 or +1.5 i don't know, but i do know that about 1.5" drops don't produce 3 degrees of negative camber.
anyway, 0 out the toe and you don't really need a camber kit, unless you want to adjust for more negative camber which some of us do. you're right about the no good front camber kits, i wish skunk2 would make their DC2 kit for the lude, even if it's hard to keep the camber locked on that particular kit.
Old Jun 7, 2004 | 07:06 AM
dc5r2002's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker &raquo;</TD></TR><TR><TD CLASS="quote">
my tires wear out in 6 months if i have zero camber... might as well make the most of it. </TD></TR></TABLE>
if you drive around with zero camber the car must handle like ****
d17civic
Honda Civic (2001 - 2005)
Aug 21, 2008 05:32 PM
Griff
Apr 21, 2005 02:20 PM
BlissSkr
Sep 23, 2004 08:34 AM
Jeff99Base
Jul 18, 2003 09:29 PM
ayacht
Oct 11, 2002 07:09 AM
