3 busted cv joints in 1 week?
Old May 27, 2004 | 04:36 PM
oMek's Avatar
Default 3 busted cv joints in 1 week?
ok to start off i lowerd my car about a month ago, and earler this week my pass side cv axle started clicking, i got a civic si replacemnt axle used for 30$ i installed that and 2 days later it started clicking.
so i said screw it and bought a 70$ autozone lifetime warrenty one. ive had it in for 2 days, last night i wint to the track and got 4 runs in.
and today its clicking again WTF.
this is when im going strate at low speeds.
what would cause a 3 axles to start clicking all in the same week? im sure i installed it right, maby the cheep rebuilt axles are just that cheep?
Old May 27, 2004 | 04:38 PM
frenchy's Avatar
Default Re: 3 busted cv joints in 1 week? (oMekoneDC2)
the autozone part might be the problem - it does however sound like something else might be to blame - how much did you lower it?
Old May 27, 2004 | 04:41 PM
oMek's Avatar
Default Re: 3 busted cv joints in 1 week? (frenchy)
it was slammed for about a week but now i raised it up and there is atleast a 1 1/2-2in gap from the fender to the wheel.
Old May 27, 2004 | 05:52 PM
oMek's Avatar
anyone got any ideas on what would make a cv axle wearout in 3 days?
Old May 27, 2004 | 06:02 PM
Bay_707's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote">anyone got any ideas on what would make a cv axle wearout in 3 days?</TD></TR></TABLE>
poop?
Old May 27, 2004 | 07:23 PM
teggytegteg's Avatar
dude i got the same pronlem wit my ****. some folks told me to get a camber kit but then again ive read that it only helps the tires. but r your axles riding bent like at the outer boot is it bent? cuz if it is damn its a bitch hhaha.
Old May 27, 2004 | 07:36 PM
oMek's Avatar
Default Re: 3 busted cv joints in 1 week? (teggytegteg)
huh?
Old May 27, 2004 | 11:19 PM
BLKMGC1's Avatar
did you check both axles if the cv boots are cracked. the cv boots are supposed to be packed with grease. once the boot is cracked and all the grease leaks out you start to hear that clicking noise when you turn.
Old May 27, 2004 | 11:28 PM
Axle's Avatar
Default Re:
I've heard that if you install them with the u-joints at too great of an angle, they can wear prematurely. I've also heard that there are some axles, I don't think a lifetime warranty one would be, but that some axles come greaseless and you have to pack it yourself, that could also be something. Obviously if it's bought sealed, then that's probably not the problem.
Old May 27, 2004 | 11:37 PM
oMek's Avatar
Default Re: Re: (Axle)
the boots where all fine, the 1s i got form autozone where alreay sealed boots so i dont think i need to pack them, im gona be going and braket racing tomarow so we will see if the axle holds up, if it dont im gona take it to a shop and see what they say.
Old May 28, 2004 | 08:00 AM
vtecmissle's Avatar
they dont replace the bearings in the axls at most stores. The rebuilders take the best used parts they get out of other cores and build the reman ones from them. I got 2 mazda axles once that were broke and welded back together. This is on a protege stock i broke them in regular driving and autozone said they couldnt find my warranty so i was **** outa luck. Same rebuilders for autozone napa etc same part numbers also. I went to another autozone and had no problems finding warranty info on their computer go figure.
Old May 28, 2004 | 09:16 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (vtecmissle)
that's why you always keep receipts for lifetime warranty items.
Clicking when going straight? Are you sure it's the axle? Are you sure you replace the right one? Maybe it's the other axle that's bad. I personally would just replace both of them depending on how old the car is.
Old May 28, 2004 | 09:41 AM
oMek's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">that's why you always keep receipts for lifetime warranty items.
Clicking when going straight? Are you sure it's the axle? Are you sure you replace the right one? Maybe it's the other axle that's bad. I personally would just replace both of them depending on how old the car is.</TD></TR></TABLE>
ita gota be that axle, when it gets loud i replace it and the sound stoped for 2 days then it came back, i changed it agaiin and the sound was gone again.
Old May 28, 2004 | 09:43 AM
Community Builder
Default Re: (oMekoneDC2)
ita gota be that axle, when it gets loud i replace it and the sound stoped for 2 days then it came back, i changed it agaiin and the sound was gone again.</TD></TR></TABLE>
Oh well, lifetime warranty, just get another one. Maybe you got a dud.
Carasith
Nov 15, 2018 06:03 PM
GeezerGSR
May 29, 2008 06:43 PM
EK_B
13
Sep 12, 2007 07:14 PM
AaronJ
11
Dec 3, 2003 09:37 AM
leadfoot78
May 26, 2003 12:17 PM
