Need Help: Fender Removal
I need help removing my fenders on an '89 CRX. I allready got the 2 bolts by the turn signal, the three in the engine bay, and one of the two by the side skirt, however, I can't get the second one by the side skirt, or the one thats just south of the side mirror. Can anyone help? Or tell me how they got their fenders off?
Thanks
Thanks
well i know where they are, i just can't frickin get to them, and that drawing does not show the additional one next to 13(bottom right) and the one at the backside of the fender below the mirror
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhetorical »</TD></TR><TR><TD CLASS="quote">well i know where they are, i just can't frickin get to them, and that drawing does not show the additional one next to 13(bottom right) and the one at the backside of the fender below the mirror</TD></TR></TABLE>
open the door, and you will see one on the bottom. I forgot if me and my dad took off the black molding on the bottom because there was one there also. After that, thats pretty much it, it should come right off. Make sure to have a small extension, the room is shitty getting to that bolt
the rear moulding has to come off, may as well take out those clips inside the fender also cuz it won't come off with them in there..
should be just that upper bolt behind the front of the door.. its hard to get at, but with an extension you can do it. same with the bottom one.. on the bottom i used a wrench to loosen it, then got it the rest of the way with my fingers..
